F-1 V8 Hood Inner Air Defector ?.
They are different, 6-cyl vs. V8. AFAIK no one repros the 6-cyl piece.
https://www.ford-trucks.com/forums/1...-question.html
Hood deflector
Pete
As best as I can tell, no repro 6 cylinder deflectors are available. I have a V-8 deflector, but I moved my radiator to the 6 cylinder position for clearance between the engine and electric fan.
So I am still looking for a 6 cyl deflector. I'll find one someday. I am in no hurry.
Thanks
Dan
Thanks
Dan
One more follow up.
My holes looked just like the photo Ross posted. And I fit it in that way this afternoon. Dan, that pic you posted was awesome BTW!
I positioned it in the center rib first. Then positioned the holes on the left and right. Now I don't want to start an argument about the air deflector's structural property in the hood assembly, but I'll just share this and it may help explain why I had the question to begin with. With the deflector in position and centered in the correct slotted hole in the center rib with the single bolt tightened, I had to pull the left and the right side of the hood in 1/4" or 5/16" towards the center line in order to get the slotted sheet metal screws in on both sides. My hood hasn't been wrecked and hammered back out. It is about as straight as they come. Without the defector, the sides deflect out ever so slightly whereas with the deflector in place, I can almost hold a straight edge on it. Thus, the center to center dimension of the slotted holes on the sides changed 1/2" to 5/8" with the defector in place. And that is why I wanted it in place before blocking and sanding, even though my hood is almost perfect.
Thanks again for y'all pictures and support.
The following users liked this post:
I saw a 6 cylinder one come up on eBay today:
48 49 50 51 52 FORD PICKUP TRUCK F1 HOOD AIR DEFLECTOR PANEL 6 CYLINDER
I'm trying to put a reproduction V8 air deflector into a nice used hood (from a V8) that's missing its deflector. The holes for the screws at the ends of new deflector are about 5/16" closer together than the narrowest point of the holes for the screws on the hood. The hood has been carefully stored for 20 years since the deflector was removed. If someone has a new repro deflector on hand, I'd like to know the exact distance between those holes. Also, would like to know the same measurement on an original V8 deflector that's still in good shape. From reading other posts, it sounds like I should just pull the sides of the hood together a bit and install the new one - and not worry about it messing up the hood. Thanks in advance for help on this! - Bob
Hood air deflectors are on the Great 8 th. Annual Parts Safari list scheduled for early Oct . Was called back for nothing last yr. Didn't get a chance to go picking , finish my brothers window install or try to harvest some Wis . speed beef . Have 3 complete Magic Air systems to pick + a list of 26 other parts . Get your parts request in asap . Thanks Denny
#28
#29
Sorry if my post was a bit confusing. I was just trying to find out if the repro air deflectors are known for being 1/4" to 3/8" narrower than the original Ford part. Threads I've read here seem to indicate that might be the case. I went ahead and used a ratchet "tie-down" to pull the hood slightly narrower and made it fit. I had been running a 6 cylinder deflector in my '52 V8 for 50 years by extending the ends about an inch on each side with pieces of 1/8" x 1" flat steel, since the original deflector was long gone. The hood I'm working on now is from a V8 truck that I bought as a replacement 20 years ago and am just getting around to installing. The seller kept the deflector that was on the replacement hood, so I bought the repro to install on it. Here's pics of the 6 cyl. deflector that I was using on my '52 V8. - Bob
The other ting that uou can do is move your radiator/fender mount forward to the I-6 holes. You can then use the I-6 baffle. This gives you more space between the front of the engine and the radiator. Of course if you are not using an electric fan then you have to extend the fan shroud . . . which should be easy enough to do with a strip of aluminum.
#30
If the width of the bolt holes was posted, I missed it. This may give you additional dimensions.
My 48 V8 hood measures 33 3/4" outside to outside across the mounting bolts with an original air deflector..
The bolts measure 32 3/4' center to center.
I don't have a reproduction deflector to compare. I doubt that you will hurt things by moving the hood 5/16".
