Manual to auto crossmember interchange
I'm gathering parts to eventually convert my 1970 F100 360 3-speed to C6 automatic. I know the manual and auto crossmembers are different, does anyone know for sure if a dentside crossmember is the same as a bumpside? Found a 78 and 79 in local junkyard, both auto, and want to get a crossmember if it's the same.
They are different from the cab back. Where the transmission crossmember bolts in is the same. People swap dent I-beams into bumps all the time to get disc brakes.
on
That way you'll have a better idea what's what!
In stead of hear say, then all screw ups will be yours.
Orich
crazed87bronco
26
05-09-2011 09:43 PM
