My garage is too low - truck will not fit even stock height. My tufskinz should arrive tomorrow. I'll put up pics by the weekend after I install them - went with Brushed Silver.
what brand of tire did you get Goodyear or Michelin? I prefer Michelins and they installed the Good for a year tire
I see why you got them you have 20 inch rims. mine are 18s but I have seen a few trucks delivered recently with Michelin's I see your spare is not a Michelin. my 2015 had the same for spare as the truck
Ah, gotcha. 20vs18.
Yes, the spare is a GY Wrangler Kevlar-type tire. Hope I never need to use it.
I wish the Michelins were a little wider but they seem to be just big enough to not look too skinny. 275's now - will upgrade to 295's at some future time but may switch brands then - I don't think Michelin has the LTX M/S in a 295x65x20.
Installed the stronger intercooler pipe today - no real advantage over OEM x/c it is made from stronger material and the hose clamps are seriously stout vs. OEM. Took about 30-40 minutes total, taking my time.
I put a gentle tie wrap on the hose to pull it back and make sure it did not rub - good point. I also had a rubber vacuum line cap that I placed on the threaded rod to make sure it was rendered harmless. Can't hurt I figured...
Beautiful truck! I also Have the white platinum, I probably wouldn't have ordered it but the truck I purchased had it. Glad it did in the end I love the color.
