93 f150 fuel pump keeps going out
I have a 4x4 93 F150 with a 300 4.9 strait 6 motor with 5 speed transmission. I had replaced the original gas tank because it was rusted out and leaking with a tank from a 95 f150 in better condition. After doing so the fuel pump went out and I replaced it along with the fuel filter and check the fuel pressure at the fuel rail and it was at 65psi. This worked for a month before it became weak so I replaced the fuel filter and the "sock" on the pump and cleaned the tank. The pump went out within the next week. So once again I replaced the pump etc and the truck ran fine for 2 days before it started to stutter and died on me. Checked the pump and it had once again quit on me. Im not sure what the problem is I had thought it was trash in the tank but I had thoroughly cleaned out the tank before I put the last pump on. Any ideas as to what my problem is? Thanks.
hartattack3
04-22-2006 10:18 AM
