Love my '06 PSD; should I fix the rust?
Hi All
Been a while since I've posted... I love my '06 F250 PSD AKA the "Brown Beast". Most reliable towing truck ever, I can tell what she wants by the way she sounds (and sometimes by the OBD codes), I can change the filters and oil in my sleep, but, she's starting to rust, diesel is more than gas, and I'm starting to get tired of the 'work truck' ride.
Have replaced the oil cooler, done an EGR delete and have a K&N intake... should I spend the money to fix the rust and put up with the ride? Or is it time to look at a newer truck?
Thanks
/trill
Thanks
/trill
I will have to replace my front fenders and drivers door this coming spring on my '03 but that is the only place I have any serious rust, fluid film has taken care of most other places very well. That said if otherwise mechanically sound I would repair any rust you can, a better investment in my mind. I would recommend however getting rid of the K&N air filter and going back to stock before you dust the turbo and possibly damage other internal engine parts, documented fact by many on the 'net.
Thanks so much for the advice! I put better shocks on a couple of years ago but it still rides hard, not so bad for me but not so great for granny, hubby or my groceries.
The rust was way worse than I thought, pulled the inside panels off, all four doors are rotten on the inside half way up, possible the paint is what is holding it together. The parts of the truck I could get at to wash regularly with a pressure washer, like the bed, bumpers, wheel wells etc. are in good shape.
I got some estimates on the body work and better shocks as I haven't the equipment, knowledge, or garage space... I was close to needing CPR afterwards.
So, much as I love Brown Beast II (BB I = '88 250 gasser) I think it might be time to go Ford shopping.
Thanks again!
/trill
Thanks again!
/trill
Hard to get a K&N clean
I agree there are lots of reports of problems with the K&N intakes. As you know a dirty filter is death to an engine. What I've found is that K&N filters are really, really, really hard to get clean, and the time between cleaning is half, or less, than what the manufacturer says, at least in my driving environment.
That said, a cleanable filter is an economical choice if one is willing to spend 45 minutes every four to six months elbows deep in a laundry tub, and dang she breathes easy with the clear airflow. I don't see improvement in city mileage but towing performance was noticeable.
