1991 bronco rear end - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 09-18-2017, 02:08 PM
kx125str99's Avatar
kx125str99
kx125str99 is offline
kx125str99 is starting off with a positive reputation.
Hey guys i grenaded the rear end in my 91 bronco last time i went 4 wheeling. I dont wanna dump a bunch of money into it because i plan on selling it soon. It has stock gearing. Will the 80-86 bronco rear end work in an exact swap with the 87-91 bronco. Or does some work have to be done. I have seen some rearends from the older years for sale. Thanks for the input in advance.
Old 09-18-2017, 02:46 PM
kx125str99's Avatar
kx125str99
Or will the 92-96 rearend work.
Old 09-18-2017, 03:12 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
any 87-96 stock bronco/f150 rear diff will work. some 80-84 bronco's had a 9" diff which you dont want to run.
Old 09-18-2017, 03:43 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
There was more than 1 gear ratio available so you need to make sure the replacement has the same gearing.
Old 09-18-2017, 06:09 PM
kx125str99's Avatar
kx125str99
The diff cover doesn't have the tag on it anymore. Is there any other way to tell what gear ratio is in it.
Old 09-19-2017, 10:33 AM
Kemicalburns
i believe there is a way to turn the axle shaft and count the rotations of the pinion. or if you pull the cover it may have the gear ratio on the ring gear.
Old 09-19-2017, 11:14 AM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
The most sure fire way to check the ratio is to divide the number of teeth on the ring gear by the number of teeth on the pinion gear. The easiest way kind of depends on how badly damaged the rear axle is.
If you do go shopping for junkyard axles, pull the cover and inspect the internals and both shafts as well. The shafts wear out where the axle bearing rides.
Old 09-26-2017, 08:23 AM
Conanski's Avatar
Conanski
Conanski is offline
What is the axle code on the drivers door pillar.
Old 09-30-2017, 09:50 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
Also look at the front axle tag.
Fishin76
02-24-2017 08:16 AM
Los_Control
Bronco II
02-03-2017 10:23 AM
gov2mod
08-16-2016 06:34 PM
mike
06-07-2016 08:09 AM
BigLarry
04-28-2016 08:01 AM
Quick Reply: 1991 bronco rear end
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
