drivers seat replacement help needed
Found a nice heated seat at a salvage yard but mine is not heated. Will the wiring harness work or will it need cut and spliced?
How do you remove the torx bolt that attaches the track at the rear inside location when the seat cannot be moved due to no battery? Or does the seat need to be removed by the four mounting bolts to the track first?
