'56 F100 Barn Find-Road Trip-Rebuild!! (PICS)
#61
Thank you so much Greg! I really appreciate that.
Today, I finished the drivers side front cab corner. Well, when I say finished, I mean the metal work part of it. This morning it started off looking like this...
Yeah, kinda grim huh? I'm really not sure if I do things the "correct" way or not but a few hours work...
I made a new front for this little "hatch" in the front corner, which I do not know what it is for yet. But I made one anyway.
A good few hours work today. It rained a lot but I shut the door and got on with it.
I was happy with todays work. Hello!!!!!
Thanks for looking guys! Gary.
....just stumbled over your thread.
You need to drill a hole for the fenderbolt in your new patch, to get access to this bolt you need this "door" / front cover, you made.
#63
#69
$17 at Lowes for a 6" x 25ft roll. There's much argument regarding this product in comparison to Dynamat and the like. Personally, I cannot afford Dynamat so I look for the next best thing within my budget. This is it. Does it smell? Nope. Should you stick it right by a direct heat source or the roof? Nope. Does it work? Yes. How do I know? I've used it on four classic VW projects, it definitely works - if you are expecting it to magically make your truck sound like a Prius then you will be disappointed, but it cuts tinny vibrations down considerably, particularly when used with carpet underlay, to which Super 300 spray adhesive sticks wonders. How many rolls to do a 56 cab? 3 with a little left over.
I know it'll probably cause some angst, but this is what I use and it's great. EDIT: I forgot to mention I use Aluminum Foil tape to seal the edges.
#70
#71
As for the roof, high temp spray adhesive and 1/2" foam to start, then probably some fabric. I've done this in my Volkswagens, I'll see if I can get a picture of that for you.
EDIT: Found two pics. This was with hi temp adhesive, 1/2" foam and some fabric all from Wal Mart! I was about $20 all in on this headliner. It was rigorously tested too every day I parked my bug at work and the Utah summer baked it to death. It did not lift or release. Much recommended as a cheap alternative to expensive headliners.
#72
Ok, back to the truck...
I had no energy this evening, but I had to do something, so I had a good tidy-up, and have the cab ready to put up on the frame at the weekend - this is for space reasons. Also, here in Utah, any day now it'll snow like a scene from A Christmas Carol, and I want the truck bed inside.
Still, looking slightly more like a truck this evening, as I had to do a quick mock-up!
#74
Glad I could pass on the idea! Hey definitely make sure you get the really sticky spray adhesive. 3M Super 77 was NOT enough, it lifted so I went with Bostick Heavy Duty 300. 3M Super 90 should be fine in your part of the world. Spray both surfaces, wait a minute to tack up, then in you go. It gets a little sticky with overspray so work clean, wear latex gloves as dirt just from your hands can pass into oversprayed adhesive then you have a dirty spot that you will never get clean. Good luck and show us some pictures brother!
#75
