2002 7.3 won't idle after cups and injector change
#46
IPR changed. Truck started after a few seconds of fast cranking which sped up until it finally idled. Everything looked normal on the scope. Injector pressure and duty cycle were normal. Truck idled smoothly but still had the stumble as I ramped up the RPM to 2000. After a few minutes, it seemed to lose the stumble and ran smoothly. I did some fast throttle bursts up to 2000RPM then let off to see if it would idle. No issues while it was still cool. After it warmed to around 125F oil temp, I gave it some throttle and let it return to idle. Died. Cranked and had the same exact results prior to changing the IPR. ICP was 240ish and duty cycle climbed to 99%. No start. Unplugged the ICP sensor pigtail and tried again. This time, ICP hit 2169 with a duty cycle of 31% but still no start. What in the world is going on here? Buzzed all injectors again with good results. I'm at a loss here.
#47
#48
#51
#52
Wow, that's pretty good service from those trucks! I've known 2 others that had the same issue right at 240k. I was told by a diesel mechanic that the 7.3's had that issue pretty much at 240k. I'd say you had exceptional service out of those trucks. Mine was a service truck in Dallas area with hot as hell Summers so I'm pretty happy with my 240k and no major issues!
Good idea.
#53
I'm curious about your driving. Long haul highway miles or lots of city driving? I know several co-workers who drive Powerstrokes and can't recall any that have gotten that many miles without cup and injector work. Whatever you are doing, must be working pretty dang well.
#54
Both city and highway. I've heard 250k or so was the limit on the injectors also. I think that's mostly a holdover from years and years ago. All except one of the properly maintained super duty's I've been around have had their injectors and cups last longer than 250k. The one that we changed the injectors and found a cup leak along the way was bought used so we don't know what happened before.
#55
#56
when did you see 2000 psi and have a no start? When the ICP was unplugged? Your PCM defaults to that number when the sensor is unplugged. You actually only had the 250PSI and that is why it wouldn't run.
#57
Yes, I unplugged the ICP pigtail just for grins then cranked. I thought there might be a sensor located in the system that actually read the pressure but I see what you're saying. I'm worn out with this truck. Sadly, I'm doing all of this just to sell it. Nobody would want it in the state that it was in puking diesel into the coolant. Might have been better off to just sell as is. I just hate seeing a good truck go to waste. Hell, I may keep it at this point if I ever get the issue solved. It's a utility body crew cab and sure comes in handy. Thanks for the advice. Come Monday, it's time to open it up.
#58
#59
Is there any way that I can monitor each cylinder via AE scan tool to see which one is not opening? I can't help but feel that it's one injector that's goobered up. I'd try the air test but I don't hear very well anymore and might not catch it.
#60
Finally found a shop guide to diagnose a no start or hard start condition. It's long but pretty comprehensive. Does require special plugs to block off one side of the engine at a time.
Here's a link to the PDF:
http://www.shopinjectors.com/diesel/...nosis-info.pdf
