85/86 f150 evp solonoid
Today while changing the oil in my truck I noticed a vacuum leak that I could hear . It was the evp, the plastic on the bottom of both of them were the vacuum lines attach had crumbled . I had been looking for a vacuum leak for a while so at least I found it ...
Any idea of were to find a replacement set ? I have not been able to . Could something fro ma newer truck be made to work ? Is there a way I can temporarily disable the egr ? i need to be able to drive my truck it is my only vehicle and I have a hunting trip in the morning .
Just plug the lines so you do not have a vacuum leak. You can leave the sensor connected. The computer will try to open the solenoid which is supposed to apply vacuum to the valve, and then it looks at the sensor to see if it moved, It will try this a couple of times and when it sees it doesn't move, it will throw a egr code.
Obviously since you have had this problem for awhile, you have been getting codes the whole time, it hasn't been working with the valve being bad. A code like this usually doesn't light up the check engine light, at least on the very early trucks. I haven't been running the egr for years on my ranger and it does throw a code 31 but it never lights the check engine light.
After you plug the vacuum leaks, you may notice it affects the idle and it may stall on you a few times. If you have ever monkeyed with the idle screw, you may need to re-adjust it. Regardless, you will probably need to let the computer relearn it's idle strategy a little bit, it was running with that false air entering the vacuum leak, and now that you got rid of that, it needs to readjust itself to control the idle.
This places carries some, I didn't look your model up.
http://www.autopartswarehouse.com/sh...noid/ford.html
You may have to change your terminology around a little bit and experiment with calling it different things. You will notice they call it a EGR Vacuum Solenoid in the above link. The Ford fuel injection book I have officially calls it a EVR valve for "EGR Vacuum Regulator" valve. You then have the EVP which is the "EGR Valve Position" sensor which mounts on top of the EGR valve and tells the computer the position of the EGR valve.
That valve looks different than most that I have seen on the older efi trucks. It looks like a pair of solenoids. Do you know how it works?
The picture above is the one my Ranger has and the one the fuel injection book describes. It has a foam filter under that cap. When the valve is off the engine sucks through that foam filter, which is prone to clogging and needs to be cleaned once in awhile. When the computer wants the egr to open, it activates the valve and it redirects the vacuum from the foam filter to the vacuum line connection which leads to the egr valve. The solenoid modulates or "bounces" on and off to control the position of the egr valve.
Most of them that I have seen look similar to the one from your ranger . It looks like the 85 and 86 mfi used the double style as well as some other mid eighties ford cars that I don't think are mfi .
I am unsure of how it works . There are two of them as one unit . looking at them from the front of the truck the one on the left connects directly to the one on the right with a very short vacuum line directly under the pair of them . That goes into a three way T on the right one that then connects to a vacuum source and to the egr . The one on the left has an external replaceable air filter . They sit under the vacuum reservoir directly behind the battery to the left of the the tad and tab when looking at the truck from the front . Seems like a complicated way to do something simple .
Thanks for that info. Interesting that my book doesn't show that type of solenoid system(or it's in there and I missed it). I see it mentioned the EECIII system also, so I am wondering if this is a very early way to control the EGR valve. Confusing when the OEM's develop and improve a system during production. They all did it.
With that calibration number, either ND or JEFF can get into the correct parts list and give you a Service Number. Make the search a lot easier.
You might be able to find one on e-bay, I bought a few over the years.
E5TZ-9D474-B 1985 FORD TRUCK EGR VACUUM SOLENOID E5TE-9D474-B3A NEW | eBay
