Bad Bearing type noise
we are new to the diesel world, so please excuse my terminology. We recently acquired a 2008 F350 6.4 liter powerstroke. The truck is making a noise that we can not pin point. It sounds a lot like a bad bearing in and idler/tensioner pulley. We went and purchased the belt and pullies. The noise is still there. (we started it for a few seconds before the belt was installed, and the noise was still there.) the noise sounds like it is coming for the right side, however I can not verify it. Any advise/pointers would be greatly appreciated
Yep. The alternator belt. But if you found the broken manifold bolts, that's likely what you're hearing. I bet the noise is loud when you're on the gas, and it comes and goes. That's from the heat swelling the manifolds up a little and closing the gap. In the mornings I bet it's real loud from the turbos increasing the back pressure to speed up the warming up of the truck.
You'll need to remove the outer belt for sure. You'll also need to remove one of the lower fan stator/housing bolts as it goes through the middle of the a/c belt. I also believe that the tensioner, or one of the idler pulleys for the outer belt has to be removed as well in order to allow inner tensioner to come off. It's been a couple years since I did mine.....but I recall one of them being in the way. I did mine without removing the wheel well liner. Did them from the top....removed the top portion of the fan shroud to allow access. Both belts and all tensioners and pulleys can be accessed either from above or below.
I replaced my outer serpentine belt about a year ago, but didn't do the single alternator belt and tensioner because it was very cold and raining, and I thought I had to remove a motor mount. Now I think it's time because of the grumbling and growling noises. I have 125k miles and 5.2k hrs on the clock of the '08 F-350 6.4 diesel. How difficult of a job would it be to just replace the alternator belt and tensioner?
