2.5" Lift & 4 Link - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2.5" Lift & 4 Link
Old 09-12-2017, 05:56 PM
Pickupman2004 Pickupman2004 is offline
Pickupman2004 is starting off with a positive reputation.
2.5" Lift & 4 Link
Is it possible to do Icon's 2.5" lift with a 4 link? If not, what is the feed back on the PMF 3 link arms?
If I lift the front at all I want to be able to make all other adjustments up front so that the axle is positioned correctly (which besides the above would also include an adjustable track bar).
On a related topic, is anyone running traction bars in the back? If so, what brand and what is your feedback?
Old 09-12-2017, 07:14 PM
honda250xtitan honda250xtitan is offline
honda250xtitan is starting off with a positive reputation.
IMO traction bars on any solid axle, leaf sprung truck are a huge improvement regardless of make/model. I ran some homemade ones on my titan for 6 years, eliminated all wheel hop, felt more stable without feeling harsh like a rear sway bar does when you go over uneven terrain.
I've read the traction bars should follow the angle of the drive shaft, i'm sure theres some magic number they should be for a f250 crew cab short bed. I ran FK Heim's with high misalignment spacers on the front and standard rubber bushings for the rear. never had a single issue other then basic maintenance/replacing heims when they needed.
Old 09-13-2017, 09:25 AM
I have traction bars on my current old 2007. Unbelievable how much of a difference they made. Not only did it help starting from a stand still, but even on the interstate it made a difference.
The guy that did my 2007 was in Ft. Myers, FL. From what I can tell, he is no longer around. So, I need to do something else.
Old 09-13-2017, 10:09 AM
Tricon's Avatar
Tricon Tricon is offline
Tricon is gaining momentum as a positive member of FTE.
I don't think I've seen a short enough 4 link kit out there yet. 4.5in lifts seem to be where they start. I'm sure PMF would make you one though.
Old 09-13-2017, 10:25 AM
According to PMF website, their 3 link arm fits stock trucks and up to 7" lifts. I am just do not have any history with their products.
I am familiar with Icon as I used it on my old 07. However, I don't think I need to go any higher than 2.5" on the new 2017 in order to fit a 35" tire on a 20x9" wheel.
As mentioned above, seems like 4" lifts is where a 4 link becomes an option. Wasn't sure what the driving reason was.
Old 09-15-2017, 01:32 PM
theres a guy in florida called "Wicked Customs" he could build you a set. honestly i built my first set of traction bars when i was 19 with zero experience. they were still on the truck in July when i traded it in for the Ford. its not complicated, expect to pay around 100$ for quality heims, misalignment spacers, bushings, and hardware. steel cost is like 30$ unless you buy steel at Ace or Home depot
welded tabs on the u bolt plates, the bushing bolted to those. welded tabs to some 3/16th 2.5" angle iron, then that got welded to the frame rail. use some 1.75 .120 wall tube for the bars.
fabtech dirt logic adjustment Fatbob316tx Offroad & 4x4 8 09-12-2017 02:21 PM
V codes with 2" hangers/shackles, adjustable track bar needed? hink10 Excursion - King of SUVs 16 08-01-2017 10:36 PM
Adjustable Track Bar or stay with Stock? allingeneral 1999 to 2016 Super Duty 2 05-12-2017 03:42 PM
So lift on top of ATS springs. A quick "How-To" Apocalypse Excursion - King of SUVs 66 03-22-2016 06:10 AM
Removing Pro Comp Lift from Early 99 ??? fastbacker 1999 to 2016 Super Duty 1 03-06-2016 09:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
