1967 f100 4x4 Front axles repair or replace - Page 2 - Ford Truck Enthusiasts Forums
Old 09-28-2017, 04:00 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by bigwilliejoe View Post
Partner, I am about there...lol
NOW, I am not too sure I got original axle shafts. While trying to solve my first problem (scored seal surfaces and such) I see that my shaft is different from the rest of the ones shown online.
F100 4WD: 1966/67 is one type, 1968/71 is another. 1972 is different again.
If the AXLE code stamped on the Warranty Plate has a 3rd digit, it's related to the front axle.
Ford/Dana AXLE ID tag located under one or two of the bolts that retains the inspection cover to the housing.
The problem is, many of these tags are missing today.
Look for a BOM number stamped on one of the axle tubes.
Old 09-30-2017, 11:02 PM
bigwilliejoe
bigwilliejoe is offline
bigwilliejoe is starting off with a positive reputation.
I need an F150 or bronco '70's don't I?
Old 09-30-2017, 11:07 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
Yes, Get one from a 1976 to 1979 F150 or a 1978 or 79 Bronco.
Old 10-01-2017, 09:40 AM
willowbilly3
willowbilly3 is offline
willowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to all
Why not do the speedi-sleeve repair? Pretty inexpensive
Old 10-01-2017, 11:21 AM
NumberDummy
No.
1966/77 Bronco is different, and you need to get one from a 1966/67 F100. Otherwise, you're SOL
I looked the puppy up in the parts catalog, 1968/76 F100 is different ('76 was the last year for F100 4WD), as is any year F150.
1966 was the first year for F100 4WD's with coil spring front suspension. 1959/65 F100 4WD's have leaf spring front suspension.
Old 10-14-2017, 10:40 AM
bigwilliejoe
I was on my way to doing so but was advised that the fix wouldn't be permanent. Also the bearing surface on one axle is dished (dips in the middle of its path) so the sleeve would have no support.
I lov d the idea though.
Old 11-08-2017, 12:10 AM
bigwilliejoe
Originally Posted by orich View Post
My swap was easy to the disc brake axle. Had to change the Front rubber flex lines changed over.
So had to re-plum the hard lines over. Then added a Proportion valve that was adjustable into the rear hard line. That was it.
I kept my truck with the manual steering and did not want to mess with putting in any of the old steering power assist crap.
Or any other home made custom linkage!
I used my pitman arm as it's the same length as to power assist unit which was easy find on ebay if your needs replacing. The steering mid shaft u-joint is also replaceable.
Orich
Hey Orich
Bought a '77 and am going to rebuild. Did you rebuild yours? If so, where did you get the parts? You got an adjustable proportions valve...?
My truck has PS on it now so did you opt not to add or did you remove?
Sorry for all the questions.
BJ
Old 11-08-2017, 11:00 AM
willowbilly3
I guess it would depend on how hard and how often you use the 4x4. Just occasional light off road use it might last a long time. I've done sketchier stuff than that as a temporary and had it still working years later
Old 11-08-2017, 10:09 PM
bigwilliejoe
Oh, buddy, me too lol. Sketchy is my middle name. BUT my son will end up with this truck and I can lose sleep worrying.
Old 11-09-2017, 11:36 AM
willowbilly3
Haha, hear you. We don't forget what we did at that age. But the first time he gets it stuck crossing a ditch or something, jackhammers the throttle with the front wheels cranked, about 3-4 wheel hops and the front end is going to explode anyway. (psst. that's what I did to my first 4x4 and it wasn't 2 months old yet}
Old 11-09-2017, 08:06 PM
bigwilliejoe
Okay gentlemen, I have another question for you. I have access to a '78 F150 Dana 44RS axle, can I use it in place of my '67? I was fully intending a '77 but the donor turned out to be a '78.
Help. It is ready to be shipped to me across country.
Thanks guys.
Old 11-10-2017, 09:07 AM
orich's Avatar
orich
orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Sorry, I can't help ya with that question. It's over my head good luck with your project.
Orich
  #28
Old 11-10-2017, 12:06 PM
willowbilly3
Having never done that swap and knowing Ford's predisposition to changing things, I would want a whole donor vehicle. But my random guess is 2 very similar front ends so it shouldn't be re-inventing the wheel
68Mercury250Ranger
Ford Truck Parts for Sale
01-22-2017 01:23 AM
ihateminimumwage
08-30-2011 02:39 PM
1967 Ford f100
02-23-2011 08:15 PM
67 Merc 4X4
02-09-2009 01:54 PM
flyingsheep
10-14-2002 12:33 AM
Quick Reply: 1967 f100 4x4 Front axles repair or replace
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
