front end information and guidance - Ford Truck Enthusiasts Forums
Old 09-11-2017, 09:41 PM
Blackbeltdually Blackbeltdually is offline
Blackbeltdually is gaining momentum as a positive member of FTE.Blackbeltdually is gaining momentum as a positive member of FTE.
Greetings Gentlemen,
Recently found my right front tire cupped and need to take the truck into have a front end alignment or have it checked. But before I do such things I like to have as much knowledge as I can. I have a Chilton book for my truck and when it comes to the front end it has a note that says the 99-04 2wd truck ball joints were not replaceable. Yet as I have searched and read for information here I think I read of guys replacing ball joints. So please help me understand what I can expect for an alignment. If major parts need to be replaced I want to do that myself and then have the alignment done, but I don't know the possibilities. What do I need to know? I do think I have recommendations for reliable and trustworthy places that can do the work, but I like to know what I can. Thanks in advance.
Just in case all things are not clear it is a 99 F350 6x2, 7.3
Old 09-11-2017, 09:45 PM
Colorado350's Avatar
Colorado350 Colorado350 is offline
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
I just replaced mine last fall. I installed Moog, just make sure you get the right ones for your axle. I also did TRE, TB etc.
http://www.moog-suspension-parts.com...ri=44,3&filter
Old 09-11-2017, 10:33 PM
Thanks Colorado350. You gave me information I did not have. If I need new ball joints, which evidently are replaceable, I will go with those.
Old 09-18-2017, 10:42 PM
afmedic afmedic is offline
afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.
They are definitely replaceable. If not then I performed some magic last year. The biggest problem you'll run in to is that the ball joint press from autozone or advance isn't designed for heavy duty trucks, and you have to be a little creative with the cups to press the new joint in. It is perfectly doable though. At least you have a 2wd so you don't have to worry about the ESOF
Replacing front shocks cdf912 Ranger & B-Series 1 01-12-2018 10:13 PM
Alignment TylerF100 1987 - 1996 F150 & Larger F-Series Trucks 4 09-10-2016 04:34 PM
Suspension/Lift problem '95, F150,4x4 timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 16 05-25-2016 12:04 PM
ball joints and alignment question ufvj217 1999 to 2016 Super Duty 4 05-24-2016 09:53 PM
97 F350 4x4 Regular Cab steering issue after new tires, balljoints & alignment ??? WoodBoss 1994.5 - 1997 7.3L Power Stroke Diesel 24 02-26-2016 10:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
