Metal shavings in fuel filter opinions
Changed my filters and this was in the bottom of the filter housing. I looked on the pleats and down in the center didn't find anything. Went to two Ford diesel techs one said is was the hpfp and should do the the whole fuel system. The other said if the hpfp was coming apart the shaving would not be in the bottom of bowl and to check the filter again in 5k miles. No check engine light, drives great, no other problems. Thanks in advance.
No experience with your problem but I tend to agree with the second tech. If there is a problem, it will manifest itself. For now, a new filter is cheap compared to a new fuel system. I would check the filter in 5,000 miles and see what is in the filter.
Ford has a Powerstroke Diesel Fuel Injection Contamination Kit, p/n EC3Z-9B246-A. Cost is about $4,000 plus $1500 core charge. You would also need to drop the tank for cleaning and maybe even change the pump in the tank.
https://www.ebay.com/sch/i.html?_fro...B246-A&_sop=15
This kit is plus shipping.
https://parts.autonationfordwhitebea...kit-ec3z9b246a
So, drive it for 5,000 miles and see if there is a problem. $60 for a filter is cheaper than the kit.
Received 1,447 Likes
on
It hard to believe a part this big came from the CP4 HPFP, go to the injectors via small fuel lines, and down the return fuel line (again small fuel lines)? And to top it off the truck still runs normal.
I would say most likely this Foreign Object Debris (FOD) came from the gas station diesel pump (supplier) and the primary fuel filter did it's job.
As others have stated I would check the filter again in a few thousand miles cheap insurance. Odds are you pick that up from the station I remember one Citgo station the young guy told me they bypassed the filters because people were complaining about how slow they pumped I laughed and told him that's because they needed to be changed either full of water or filth totally true story LOL take care
What is the status of the warrenty?
If you have warranty and the system show no signs of rust, ford will warranty it.
I "think" soft metal in the pump is aluminum. Which would not stick to a magnet. That would most likely be the metal you would see coming from the pump.
It could take a while to push all stuff from the take to the main filter. Keep a eye on your fuel rail pressure
F350-6 No there isn't a magnet in the bowl,its one i used to get the specs.
I am going to check filters again in 3k or 5k just to see.
donovan Luckily i have 7yr 200k warranty. currently have 140k. Dealer showed me pics of sensors "Detroit" looks for and if any signs of rust then im s.o.l.
ruschejj I also agree that the shavings would be aluminium and not be magnetic.
Thanks to everyone. I will post pics of next filter change.
