Low Oil Pressure on Gauge. Where to Start
I have a 95 F250 7.3. I'm getting a low oil pressure reading from my gauge in the dash. I know these gauges have been known to be unreliable but it's starting to concern me. I have plenty of oil in the truck but it still reads low. Does the gauge read low pressure oil or high-pressure oil?
just wondering what the steps are to start testing and getting a better idea of what's actually going on
I'd try a new sending unit, as these engines won't run without oil pressure to fire the injectors. I was driving my 97 one day, and looked down at the gauges, and saw the oil pressure was reading 0. I about soiled my drawers, then remembered that they won't run without oil pressure. A new sending unit cured my problem.
It reads low-pressure oil, but it's just a dummy indicator. It only operates in two positions. When there's zero pressure, it reads all the way left. When there's "enough" (something like 7 PSI) pressure, it's supposed to read in the middle. So if it's responding at all, then it's working. If it's not, then there's something wrong with either the gauge head or the sender.
Remember, if you didn't have at least some output of the lube oil pump, your engine wouldn't run.
When I got the truck it read right in the middle. Recently it's read between all the way left and the N of Normal. Just today it started reading pretty much all the way to the left like in the picture. It does slowly fluctuate closer to the N but still doesn't pass it.
I would by a new sender Or check the wiring....1995 FORD F SUPER DUTY 7.3L V8 DIESEL Turbocharged Oil Pressure Sender / Switch | RockAuto
There's actually a mod that turns the dash "gauge" into a real gauge. Ford intentionally crippled the gauge into this "1/0" functionality because too many clueless owners got alarmed watching the REAL gauge pointer move so dramatically as the RPMs went up and down, and as the oil temp changed. Hopefully someone who's familiar with the mod, or at least knows where there's a thread / write-up on it, will post soon.
carpenter 68
03-13-2013 07:48 AM
