Irma 1 Excursion 0 (but, repairable!)
The little plastic barb, next to the upper radiator hose. It's where the small hose to/from the Degas bottle attaches to the radiator. I recall a thread where somebody had a way to thread a fitting in (I think).
The barb is molded IN to the radiator - solution is a new radiator, but if I can repair it (vs. buy a new radiator), have a new windshield put in, I can drive to body shops for estimates on the roof and hood.
Check this out. It's from the OBS section, but should work for you.
https://www.ford-trucks.com/forums/1...ow-nipple.html
Red
Red
That is "was" on the TODO list, before we moved to CO, I am still hoping to tow the Explorer with my Excursion. I've got a new Gendex rear-view mirror with backup/cam also on the TODO list, so with the headliner out, and a new windshield going in (hopefully) that also can get done.
on
Well then, you can keep your 1/8" tap and the associated bit for your eventual EGT probe install
I hate that for you! Check the fit of your doors, A pillars, etc. That's what pushes the ins co over to the total side. Just the sheet metal on the roof should not be too bad. A new hood is like $200-300 plus paint. I would want the whole thing painted. Really go over, around and under it numerous times. It's amazing what you DON'T see sometimes. Good luck!
Thanks. Will cleanout interior over the weekend, and vacuum up glass, remove all my things as well. Will be able to inspwct once all the glass and sawdust is removed.
The damage is not bad, it's all about the roof (inside and outside) and whether something (doors, winshield) are out of alignment.
Sounds like local Ford dealer should get power by Monday, then we'll be ready to get it towed in. I want to ensure they won't let water inside and damage it more.
Diesel Excursions, really do hold their value!!! First vehicle my adjuster has seen in Fl from Irma, NOT a total loss!!
Auto insurance will cover repairs!
State Farm, valued stock '05 Ex, Eddie Bauer w/all options, w/148k, 2wd at about $18k!!!
Didn't even need to evaluate all my upgrades to be able to get it repaired, but, we can include them later, if needed, should more repairs be needed.
About $11k repair estimate.
Have about $2k more "room" if they find something else that needs to be added.
Hot diggidity....
Hot diggidity....
on
Hot diggidity....
Hot diggidity....
#30
