1977 Long box conversion to short box 2 wheel drive F-150
Old 09-10-2017, 01:52 AM
moparmusclecars
moparmusclecars is offline
moparmusclecars is starting off with a positive reputation.
Anyone done one, and is there a certain place you should cut them down? I'd add a plate on the inside too, but just not sure best place to cut it for shortening. I am a body man, so my main concern is best place for shortening up the frame. Any suggestions would be appreciated. I have located short boxes, so that end would be covered.
Old 09-10-2017, 02:05 AM
75BigBlock
75BigBlock is offline
75BigBlock is starting off with a positive reputation.
I'm pretty sure no one has done one in the history of doing things.
https://www.ford-trucks.com/forums/1...0-f250-14.html
Old 09-10-2017, 09:31 AM
good to doo's Avatar
good to doo
good to doo is offline
good to doo is gaining momentum as a positive member of FTE.good to doo is gaining momentum as a positive member of FTE.
I did this 1 in 1980. Started with a 77f250 The box came off a 67 ford. But I couldn,t find any ford ford fenders, so I used what I had, chev fenders.
Old 09-10-2017, 09:34 AM
good to doo
This is what I started with.
Old 09-10-2017, 09:36 AM
moparmusclecars
Perfect, thank you.
Old 09-10-2017, 09:57 AM
Uni Moe's Avatar
Uni Moe
Uni Moe is offline
Uni Moe is gaining momentum as a positive member of FTE.
Old 09-10-2017, 10:00 AM
Uni Moe's Avatar
Uni Moe
Uni Moe is offline
My picture above. I actually went vertical down 1" from the top and up 1" from the bottom and joined the two with the 45 degree cut. I found it easier to line up that way.
Old 09-10-2017, 02:31 PM
moparmusclecars
I appreciate all the replies. How far back of the cab do you set this up to be cut? Is there specific measurements? I don't have a box yet, so should i make sure I have a box first, or would it really matter if I'm going to cut down a long box? I figured if there is exact cutting measurements, I could always cut my frame down first, and get a box later, regardless if I go with a short or long box. I am a body man, so I am sure i can handle this, just wanted to ask many what they ran into doing this conversion before I start.
Black Widow Modding
03-18-2016 08:20 PM
wildstang
04-03-2006 12:29 PM
lethomas
Fifth Wheel & Gooseneck RV Towing
11-29-2004 08:13 PM
parks911
15
06-25-2004 05:48 PM
azreal
04-19-2004 10:26 PM
Quick Reply: 1977 Long box conversion to short box 2 wheel drive F-150
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
