1977 F-150 Custom transmission?
Old 09-10-2017, 01:45 AM
moparmusclecars
moparmusclecars is offline
moparmusclecars is starting off with a positive reputation.
I have a 77 f-150 with what I'm told is no reverse. How hard is it to rebuild these transmissions, or is it just cheaper to find a used one? What would generally be in a truck with a 351M? I am just getting into the Ford trucks, so i figured its either a C4 or C6.
Old 09-10-2017, 02:46 AM
75BigBlock
75BigBlock is offline
75BigBlock is starting off with a positive reputation.
What's your VIN?
Old 09-10-2017, 04:49 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
It will be a C6.
Old 09-10-2017, 08:58 AM
SlikWillie's Avatar
SlikWillie
SlikWillie is offline
SlikWillie has a good reputation on FTE.SlikWillie has a good reputation on FTE.
Definitely a C6. Call your local tranny shop for a price on a rebuild. Probably around $500 or so. You can pick up a good used C6 for probably half that but you don't really know what you are getting.
Old 09-10-2017, 11:48 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by 75BigBlock View Post
What's your VIN?
TRANS code not within the VIN .. Listed by itself on Warranty Plate.
Only A/T available with 351M/400 = C6.
Old 09-10-2017, 02:21 PM
moparmusclecars
Thank you so much, everyone. Will this same transmission bolt right up to a 71 460, should I decide to put the one i have in this truck?
moparmusclecars
Rebuilt transmissions around here start at like 1300.00
Old 09-11-2017, 05:32 AM
gatorfor88's Avatar
gatorfor88
Yes it will bolt up to a 460.
Old 09-11-2017, 07:21 AM
DB429SCJ
DB429SCJ is offline
DB429SCJ is starting off with a positive reputation.
Transmission will bolt up,but you will most likely need to change the torque converter.There are 2 different crank pilot sizes. A 71 engine probably has the larger one.
Ferrariferg
Vehicles for Sale
09-19-2012 01:13 AM
tattoo1968
10-01-2011 08:22 PM
volfan
01-03-2011 11:18 PM
Mustang65432
07-10-2010 01:48 PM
biggrobbdogg
09-20-2003 08:46 AM
Quick Reply: 1977 F-150 Custom transmission?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
