First real road trip/towing report - Page 2 - Ford Truck Enthusiasts Forums
Old 09-11-2017, 10:04 PM
lpzd's Avatar
lpzd lpzd is online now
lpzd is starting off with a positive reputation.
The air is much less dense at elevation, so yeah they do tend to run little warm. Though to be honest I've never towed below 6k'
Old 09-11-2017, 10:22 PM
Colorado350's Avatar
Colorado350 Colorado350 is online now
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
Quote:
Originally Posted by andym View Post
Another question... do high elevations contribute to high EGTs? When I was crossing Vail and Loveland passes, I was in 2nd gear doing 40 or 45 and held back by EGTs. Big trucks were crawling along at 10-15 MPH. I have a hard time judging flat ground or how steep a grade really is so I'm not sure if it's because the passes are so steep out there or if the elevation had more to do with it.
I almost had to slow down on a steep grade on I-40 between Knoxville and Nashville today. Almost.
Hey Andy,
I'm going to say yes with regards to elevation contributing to EGT's. But at same time the Turbo charged engine definitely helps but thinner air is thinner air. I notice a significant difference towing regardless of the weight between 6K' and say 10K', the engine needs to work harder, more fuel more heat.
Before I bought my truck, I towed with a Jeep Commander with the 5.7 Hemi. The Jeep actually towed well through the mountains, the 4 speed transmission was the big negative. It always hunted going up steep grades but did well if you didn't push it. BUT when you started dropping in elevation, even during steep climbs the Hemi became a Beast! The temps dropped and the engine owed the road...big difference here was the elevation i.e. air available.
I'm in Colorado btw.
Old 09-11-2017, 11:32 PM
Jo7.3 Jo7.3 is online now
Jo7.3 is starting off with a positive reputation.
So now that you've towed quite a bit with the 160/80s...do you wish you'd have gone with hybrids, or are you satisfied with the power? Also, not sure if higher elevations cause higher egts, but it makes sense to me that it would. Less air up in the mountains makes stuff run hotter/work harder from my experience.
Old 09-12-2017, 11:45 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
I'm very happy with the 160/80's. No regrets at all. I feel like I have more than enough power and wouldn't know what to do with more. I'm already pulling almost half of the hills I encounter in OD at and hold them at 65-70. I can swing out to pass a truck going up a medium grade in 3rd gear, pass the truck easily, get up to 65, and not even break 1150. All while towing ~19,000 lbs total. I have absolutely nothing to complain about power-wise.
Old 09-13-2017, 12:01 AM
andym's Avatar
Quote:
Originally Posted by Colorado350 View Post
Hey Andy,
It probably does; I'm just wondering if anyone happens to know the specifics, other than just "because of less air".
That sounds exactly like my 5.8L Bronco. Sea level to 6000' made a huge difference in power. I kind of hated it.
Old 09-13-2017, 04:59 PM
carl2591's Avatar
carl2591 carl2591 is offline
carl2591 has a good reputation on FTE.carl2591 has a good reputation on FTE.
check out the https://www.flattestroute.com/,, give a graphic view of the route with grades indicated along the way..
Quote:
Originally Posted by tjmike View Post
At ~17,500 lbs my cc does not hunt on the flats and certainly not downhill. I have no tunes on the truck.
I had one case where the truck was dropping out of OD on the flats and being a gutless wuss on on the smallest hills. I changed the fuel filter (it had 3-4K miles on it) and that seemed to fix the problem.
I also end up in 2nd gear on some long steep grades. For example we were recently on the "circle" made up of 81, 77, and 64 in Virginia / West Virginia. On 81 we were able to maintain speed but on 77/64 we ended up in 2nd gear a few times.
I wish it were possible to see road maps color coded by road grade.....
Old 09-13-2017, 06:11 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
Do you stop at the truck scales?
Old 09-13-2017, 08:03 PM
bigb56's Avatar
bigb56 bigb56 is online now
bigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to behold
Quote:
Where do you tow? We towed a 29' Forest River up to Mora County (stayed at the little Inn & RV park in Cleveland) in July. I have family roots in Northern NM. and will probably be spending summers there as soon as I retire.
Old 09-13-2017, 11:18 PM
lpzd's Avatar
Just bought house in Espanola, grew up in pojoaque. My Wife likes to go camping near red river, or penasco area ( trampas trail head) .
I haven't been towards Mora in a looong time, it is really pretty country up there.
Old 09-13-2017, 11:27 PM
bigb56's Avatar
Oh nice, my cousin lives in Espanola. My great grandparents came from the Penasco area and moved to Chacon before 1879.
Old 09-14-2017, 03:25 AM
andym's Avatar
Quote:
Do you mean Cat scales or weigh stations?
Only if I want to weigh my rig, and no I don't.
First camping trip tony montana 42 6.2L V8 5 10-21-2017 02:07 PM
Possible to adjust the gain on cruise control? Nothing Special 1987 - 1996 F150 & Larger F-Series Trucks 28 07-18-2017 05:27 PM
Ecoboost Temperatures Towing FiveOJester 2009 - 2014 F150 13 06-22-2017 07:53 AM
New 5er Towing Observations 95F350CC Fifth Wheel & Gooseneck RV Towing 11 07-16-2016 01:59 PM
Turbo? Squeal at High Load and High EGT? Forest 6.0L Power Stroke Diesel 24 05-19-2016 09:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
