Well hell my dipstick flange nut came loose!
Heading back up to get the last load of antique tractors from the show and something seemed funny. 2 miles later turn into a side Road less power. Pull over. Oil everywhere. Shut it down. Nut completely unthreaded.
Get it on and tighten as best I could with a pair of channelocks one size too small. Dump in a gallon of oil. Now it is just on the stick. Start it and sounds good. Still leaking.
Called a buddy to see if he can get me. Yep sure but his wife is not happy. Something about him going to Texas at 7 am for work for a week..... Give him directions hoping he makes it since he has no sense of direction.
Obs 7.3 stops. Talk to him. He doesn't have anything better for tools on him but lives a mile down the road. Drop the trailer on the side of the road. Drive to his farm and got some better fitting pliers. Either I got too heavy handed or I cross threaded it. Stripped the nut. The flange threads look good.
Drive back to the trailer and sit intersection so my buddy doesn't miss it. Hook my trailer to his truck and get mine loaded. In the end it turned out as best as it probably could have. Pictures to follow when the sun comes up. Time to read up on the dipstick flange. Hoping a new nut and o-rings will fix it.
Feel free to point me in the right direction while I'm searching the forum.
Oil Level Gauge Adapter Repair Kit for 1994 - 2003
http://www.dieselorings.com/docs/dipstikflange.pdf
See the big boxed NOTE at the very bottom. You may have bent the inner flange.
I would get the kit, and use it, but don't expect it to really work. I could never get the o-ring in place properly. Do the best you can with this kit, and then just paint it with a ton of the Motorcraft grey sealant. As in completely encase the whole adapter and threads with it. It will be ugly, but that's the best way to ensure it doesn't leak again.
Also, change the dipstick o-ring. They don't seem to seal when re-used.
Dipstick Tube Seal (o-ring)
I don't think you can get it locally. I believe that Diesel O-rings puts that kit together themselves. It might take a lot of running around to try to piece it together. Also, whatever you do , do NOT attempt to remove the outer nut without that bore brush or similar firmly inserted in the dipstick hole. If you do, the inner adapter will fall in the pan, and then you're pulling the motor. Trust me, its a real butt clencher, even with that brush; given the consequences of failure.
Nut is already off. It was off going down the road. Need to get something on it good. Possibly grind a pair of vice grips special??? Not much to hold onto. Will be calling the 2 Ford dealers to see if they have parts on hand. Not looking forward to pulling out the dipstick tube. Wonder if I can bend the dipstick bracket and install a new nut to hold the flange to remove the tube...
Been sold out for a couple weeks. I messaged him a couple days afterward questioning whether or not he was going to build more but I haven't heard back.
Found 2 different sellers on ebay. Messaged both. One said out of stock working on a new design. No response from the other yet. Local dealer will have the nut and inside pan o-ring in the morning. Said the little one only comes with the dipstick now. Ill use one out of my assortment for that.
Any recommendations for sealant? Saw some motorcraft stuff...
I do not know if I bent the inside piece. I hope not. I plan to drain the oil and clean everything, pray I don't loose the flange, put vicegrips on the flange as the nut is already off and stripped, pull the dipstick tube out, put in a new o-ring and goop it up on the outside. what about putting some on the inside? Let it dry then dump oil back in and see what happens.
I know it was not leaking the day before as I have had a leak at the drainbolt. I replaced it with a fumoto valve and was looking at it and it was dry. on the good news my truck is ready for winter with a rust preventative coating trailer too!
Found someone in the OBS forum that had some for sale. Fingers crossed. Should fit but not tried on a newer truck yet.
https://www.ford-trucks.com/forums/1...er-repair.html
Doesn't always work, but I have found that if you find a wood screw that fits very tightly into the nozzle that you cut open you can screw it down about 1/2 way. Then I take some wrapping tape and wrap the joint between the screw and the nozzle and it usually stays fresh for a good while.
Hoping to fix it tomorrow and haul the last tractor and my camper home Saturday. I can use my friends truck for the tractor but would rather not. We drove home 40-45 towing my truck. It did ok but overloaded. Looking at the others as a backup plan including the 300 dollar option.
Really do not want the old one bouncing in the pan.
