Do you want a pedal assembly? I converted over to a ZF5 from my C6. I still have it.
I'm going to see if I can find the right shoulder bolt to remove the clutch pedal and make my brake pedal work. if that's a no go, I'll take you up on that!
got the pedals figured out. ended up just cutting up the clutch pedal. made me a little sad to do that haha. also got the transmission in place and wired in
where the stick shift and the T case shifter use to sit, I patched it with some sheet metal, painted it black to not rust and sorta blend in with the carpet. but now I have two gaping holes. if I get that cable T case shifter it would cover one of them maybe but I might have to get new carpet before too long
the fuel lines will be cleaned up and routed differently, Im just waiting for the right fitting in the mail. I did pressurize the fuel system and its all working great. I realized that even though I have hp tuners and should be able to modify the computer for running stand alone, the computer has an operating system that is not compatible with standalone tuning. the computer itself is fine, I will just need to get a slightly different operating system for that... waiting for an email back from tech support
also I've had this headliner with built in stereo and speakers for a while now, and I actually really have not liked it. I ordered a plain jane black headliner and I'll be putting the radio back in the dash. the speakers are right next to your head and its really not enjoyable
