2015 F-250 with 6r140 Transmission
Old 09-05-2017, 08:52 PM
Boo-mer
Boo-mer is offline
Boo-mer is starting off with a positive reputation.
I have 13 K miles on my truck. While pulling my Travel trailer up a hill the transmission kicks down thru the gears, which is fine, but as I crest the hill and in 2nd gear, the engine begins to rev up and the speed increases, the transmission will not automatically go into 3rd gear. I have tried to let up on the gas pedal, but it remains stuck in 2nd gear. I have to shift to manual and then put it in 3rd gear. Then it shifts up as it should. I have tried with the transmission in "TOW' and not in "TOW". I have even tried it in “Cruise Control”.
Ford dealership ran tests but could find no problem. However it was road tested without the trailer.
Any thought? Thanks
Old 09-06-2017, 08:41 AM
HRTKD's Avatar
HRTKD
HRTKD is online now
HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.
I've experienced a couple of slow upshifts in my F-350. Pressing the accelerator to gain 500 engine RPM didn't work. A couple of times I disabled tow mode and it shifted right away.
Old 09-06-2017, 10:03 AM
swarf_rat
swarf_rat is offline
swarf_rat has a good reputation on FTE.swarf_rat has a good reputation on FTE.swarf_rat has a good reputation on FTE.
I've had mine do that but only in cruise control. If it crests a hill in a downshifted gear, it won't upshift again. I take it out of cruise and shift manually, then all is well. A bug in the PCM?
Old 09-06-2017, 04:32 PM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a very good reputation on FTE.dirthawg has a very good reputation on FTE.dirthawg has a very good reputation on FTE.
I've noticed the same. Occasionally when using tow/haul with the exhaust brake engaged while descending a hill, after reaching a safe point and the need to accelerate is reached the trans will not up shift. Disengaging tow/haul will allow the up shift then I reengage tow/haul. Is this an issue that can be fixed with a flash? For now its just a minor annoyance.
Old 09-08-2017, 02:06 PM
T diesel's Avatar
T diesel
T diesel is offline
T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.
Me too. Like you're stuck in second.
Only happens when towing.
Old 09-08-2017, 09:13 PM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
I recall another thread where shifted weird that was "fixed" by clearing the learned shifting strategy. If you disconnect power in these will it then kick into a new learning cycle again or do they have to be cleared?
WarRig99
6.7L Power Stroke Diesel
12-22-2017 07:12 AM
texinwa
12-04-2017 07:43 PM
trying_to_tow
1999 to 2016 Super Duty
01-28-2016 10:16 AM
bock57
01-19-2016 03:48 PM
defekticon
09-21-2015 12:47 PM
Quick Reply: 2015 F-250 with 6r140 Transmission
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
