94 2.3L ranger issue
Old 09-04-2017, 11:37 AM
jatkins3983's Avatar
jatkins3983
jatkins3983 is offline
Alright so my neighbor has a 1994 2.3 l Ford Ranger I think it has around 100,000 miles it has 8 spark plugs for the four cylinders two coil packs. He was having multiple issues with the truck skipping bogging says the transmission feels a little funny haven't got a chance to drive it yet but yesterday we found and fixed a vacuum leak right to the fuel pressure regulator swap the fuel filter he has done spark plug wires and plugs and a new air filter. Hasn't seemed to Made A Difference he said his problem is intermittent I'ma give you a list of the codes and maybe somebody can point him in the right direction. I had a similar issue on my 88 Chevy and it turns out it was my ignition control module I think that's his problem also but it's been awhile since I've worked on Ford's
Code list as it appeared on diagnostic mode
1 1 1
1 5 7
223
224
157
213
224
any help is greatly appreciated.
Old 11-03-2017, 12:32 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is online now
Received 1,514 Likes on 1,413 Posts
111, System checks OK
157, (R,M) Mass Air Flow signal is/was low or grounded - MAF
213, (R) Ignition SPOUT or SAW circuit open or shorted - Ignition Systems
223, (M) Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224, (M) Failure in ignition coil primary circuit - Ignition Systems
It could be a failed/failing MAF but a failed coil will cause the symptoms you describe. Some vehicles/transmissions may not shift correctly with misfires.
Nicktitan
03-04-2015 03:55 PM
bobbywheels1212
10-29-2014 11:40 AM
ziggy55
1983 - 2012 Ranger & B-Series
04-04-2010 05:26 PM
Xoryx
4 Cylinder Engines
11-15-2003 02:17 PM
Xoryx
11-05-2003 10:38 AM
Quick Reply: 94 2.3L ranger issue
