Needed some advice on 93 ford f150 4.9l with the fan clutch
Was trying to remove my fan clutch on my 93 ford f150 4.9l with no progress couldn't never find the right fan clutch wrench set so I decided to remove hole assembly water pump to fan clutch, well got that done and out which I'm glad I did it that way because it let me see my water pump was bad to ,now that it is out I managed to get part of the fan clutch off enough to get fan off and managed to get most of the water pump off but still need to get pulley free from fan clutch nut and it is not breaking free, any suggestion.
If not does anyone know where I can find a water pump pulley for my 93 ford f150 4.9l i6, cause I have search the internet for hours with nothing not one single pulley for that year and motor, any help would be greatly appreciated.
Thank you,
Jonathan B
Thank you,
Jonathan B
You could try these guys
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
If there are local wrecking yards near you, check their inventory and get a used one.
old blue 90
09-25-2007 08:33 AM
don58
09-03-2003 09:24 AM
