I think the 6.2 is the gas version of the 7.3 Powerstroke
#91
Received 3,102 Likes
on
#92
#93
on
#95
Ok. I suppose you win the race up a hill. But that's not the only way to define "outpull." I'll venture that the average 7.3 goes further before a rebuild, & gets better fuel mileage. You're right about the tranny only in reference to automatic behind the 7.3. The ZF6, however, lasts forever.
That said, it's really not an either/or to me. When the 7.3 wears out (if ever, lol!), I'll be looking at the 6.8s with the ZF6 (through 2010), and the 6.2s beyond that year. Both are absolutely bulletproof. I'm not a fan of the fuel economy with gassers, but the other advantageous reasons stated, plus their simplicity in comparison with modern diesels just outweigh the disadvantages.
Now, there's a pretty good comparison. 6.8 vs. 6.2 gas motors! Pros/cons?
#96
I'm not sure what prompted the physics lesson, and I am getting more and more impressed as people really are starting to understand the difference more than they used to. However, this statement is false. Torque, while sharing a similar unit notation, is in no way work. It's a force applied at a distance about a fixed axis. It's best to think of it as rotational force, but just as linear force is not linear work, neither is torque rotational work. Linear force applied over a distance is work. Torque applied over an angle is rotational work.
I said torque is work, not power.
Then you said I was wrong, and then said "Torque ... is rotational work."
Your objection is to what, agree with me??????
Force = mass x acceleration
Linear work = force x distance as measured in a straight line
Rotational work = force x distance as measured at the radius of the application of moment arm
Power = work per unit of time
You are confusing the distance around the circumference (whether measured in linear units, or angular units) with the distance of the moment (radius); a classic misunderstanding.
Think of it this way ... consider an electric motor; a typical PSC 25hp motor that runs 3600 rpm. That 25hp rating means it's making 36 ft-lb of torque at that rpm. But even if you stalled the motor (locked rotor), there is still 36 ft-lb of work available. Rotating or dead still, the amount of "work" is the same. One is dynamic work and one is potential work. How fast it does that work is the concept of "power".
Work is ALWAYS force x distance.
Power is ALWAYS work / time.
In a rotational model you induce the element of time, because it takes time to cover the circumferential distance. Time is not of consequence to the force applied at the radius moment location.
Your objection is summarily dismissed.
#97
You used quotes and then took my statement out of context. Quotes are meant for taking statements verbatim, but you used an ellipsis to remove the vital part of that statement. For example, "Force times distance is work," is not the same as "Force ... is work." lol!
Since you made a point of unsolicitedly teaching bogus information, I made it a point to correct you. You can't convince me that torque is work, because it is not and I am well-educated. Likewise, you have convinced yourself so thoroughly that you're here trying to teach the subject and if you accomplish anything, it's going to be to the detriment of anyone trying to learn. I think my response was enough to flag to the casual reader that they should do further research. I suggest simply going to google and typing "Is torque work?" Or let me google that for you: http://lmgtfy.com/?q=is+torque+work
Here's a preview: "Torque and work can not be interchanged because they do not represent the same thing."
And a preview of "is torque rotational force": "Torque is the rotational equivalence of force."
#98
Torque is a product of an equation, not an input. (product used in the sense of true math; a product is the result of multiplying two inputs).
Your theory makes torque a "force"; an input.
Torque is rated in units of force and distance; we'd commonly say 'ft-lbs". This is because it's a mathematical formula; force x distance.
It is improper to call torque a Force. Force = mass x acceleration. We'd say "pounds" for force (Newtons, ounces, etc for units).
It is impossible for your theory to be correct. You cannot call torque a "force", because it would only have the units of force (pounds in our example).
Imagine this conversation .... "Hey Joe - how much torque does your engine make at peak?"
Joe - "925 pounds".
WRONG!
Torque is an output of a mathematical equation, not an input of force.
Like I said, you're among many whom misunderstand what torque is. Torque is rotational work. Work is force x distance. TORQUE IS NOT A FORCE; it is a product, not an input.
Think I'm wrong?
Solve this equation with the units of measure using your method ...
HP = (torque x rpm) / 5252
HP = (force x rpm)/5252
HP = ft x revs/min / 5252
In the real world, 1 hp = 550 ft-lb/sec (distance x force) / time
So your formula would be thus:
1 hp = some quantity of "force" / 5252 ( 5252 represent the unit-less conversion of revs/min to radians/sec)
1 550 ft-lb/sec = "x" lb / 5252
Where'd the distance disappear to in your method ?????
You're flat wrong; the units don't balance.
Go back to take physics again, and focus on unit resolution.
I'll let you have the last word; it'll be wrong, but you can enjoy it.
I can explain it to you, but I cannot understand it for you.
Joe - "925 pounds".
WRONG!
Think I'm wrong?
#99
Definition from Webster(https://www.merriam-webster.com/dictionary/torque):
From wiki (https://en.wikipedia.org/wiki/Torque):
From Fundamentals of Physics: Sixth Edition by Halliday, Resnick, and Walker:
In case you missed it from the picture (or if in the future the pictures no longer post), the textbook says:
It's kinda like I actually teach the subject or something... Thanks for the last word! All the best!
1: a force that produces or tends to produce rotation or torsion
also : a measure of the effectiveness of such a force that consists of the product of the force and the perpendicular distance from the line of action of the force to the axis of rotation
2: a turning or twisting force
Torque, moment, or moment of force is the rotational equivalent of linear force.
The SI unit of torque is the newton-meter (N*m). Caution: The newton-meter is also the unit of work. Torque and work, however, are quite different quantities and must not be confused.
#101
Since we like to argue, I'll say after 15 years with 2000 7.3, 12 of those "modded"(DP tuner, exhaust, intake, turbo, and downpipe) the 2017 6.2/6R140 is a better driving/towing experience hands down. If you really want to compare apples to apples, you need to put the 7.3 in front of a 6R140 at least in my case. My 7.3 had good power and would probably win a drag race but that's about it and drag racing is not important to me. For towing I'll give the nod to the gasser. The biggest difference I see is I don't have to limit my uphill speed to the EGT gauge. All I need to do is grab a gear and spin some RPM and the 6.2 goes. I loved my 7.3 and it never let me down but with 17 years difference in the trucks, one would hope the latest model is an improvement and I think it is. On paper it's easy to say how one is better than the other but towing the same loads, over the same roads, imo my 17' does a better job. It's not just the engine, it's the entire package.
#102
I don't think anyone would argue that this current generation is inferior to the older generations. The new trucks have so much more going for them and not just the engines. The entire drive-trains are better. The cabs are roomier and quieter. The functions and features are more prevelant and prominent. There are things today's vehicles can that were just dreams two decades ago. Remember, the previous SD platform came out in 1999; it was designed back in 1995. That's 25 years ago! Even a modded truck such as yours will pale in overall application contrasted to today's trucks, as you state.
The 6.2L with 4.30 gears is very comparable in terms of pulling prowess to the old 7.3L with 3.73s. And the new trucks do this with more grace and panache'. Despite what Chris and I will always vehemently disagree on, it's just a term (semantics) that we debate. The reality is that the capability of the gas system of today's trucks equals the capability of the older diesel trucks. Torque is a concept that is translated into thrust at the road surface; that's what moves vehicles. The 6.2L/4.30 is essentially an equal to the old PSD/3.73, and it does so within a more refined package.
#103
We don't have to get along or agree to enjoy the subject of the conversation. And, you're right about the semantics. Effectively, I'm fairly confident you'll come to the same conclusions I will, given the numbers. Incidentally, the 7.3 puts out ~500 lbs-ft, and the new 6.2s put out ~430 lbs-ft. If you calculate the rwtq after the effect of the rear gears, 500*3.73/4.30 = you'd need 434 lbs-ft to achieve equivalence. Pretty damned close! Of course, that doesn't take the trans gearing or tire size into account. Yeah, for me there's no concern over whether the 6.2 can pull the weight. It obviously can. I'm just happy that they've got a reliable reputation.
Does anyone know if the 6.2 improved fuel economy towing vs. the 6.8 V10?
#104
Does anyone know if the 6.2 improved fuel economy towing vs. the 6.8 V10?[/QUOTE]
In my experience no. However it blows the doors off it in unladen economy. My 05 v10 was pretty much 9-10mpg all day. Put the trailer behind it about 9k TT and it was 8.5-9mpg. So at least it was consistent. With the 25 gallon tank you didnt pass many fuel stops.
#105
When I read the title of this thread I didn’t think which motor could pull more better. I thought, that is an accurate statement. One buys a 7.3 for reliability. It was was option for 10 years, being progressively upgraded throughout the years. The same is true with the 6.2. I guess what I am trying to say is, in 10 years we will be talking about how reliable and good the 6.2 was, just like we reminisce about the 7.3 now. I guess I could be wrong though lol
Carry on...
Carry on...
