I think the 6.2 is the gas version of the 7.3 Powerstroke
#76
#77
I agree to a point, but I have Five 3 cyl Yanmar powered Deere’s myself that I would bet my life on. All were bought used through the years, and all have been flawless. These are off couse N-A and not turbo.
#78
I have a few Yanmar powered Deeres as well. They are crazy reliable and are incredibly well engineered.
#79
I know it's an old thread, but I found this comment interesting, because I've been arguing over at PS.org that if I were ever to go from my 6-spd 7.3 to a modern truck, it would be a 6.2, not a 6.7. You know why? It's the same reason that I chose the 7.3. I feel the engine and transmission are the most reliable/affordable combo currently in production!
#80
In the last year I have started seeing more and more 6.2 trucks around here than ever before. I think people are realizing they have a ton of power (I think Ford made a bad decision when they put the 5.4 in the Super Duty) and are very, very reliable.
I did a 300 mile round trip on Sunday, part of that being off pavement and on some two track dirt roads, and I got 15.3 mpg round trip with the cruise set at 70 mph.. That is in a 1 ton truck! Can you really expect much more than that? Yea, I would like to get 15 mpg when I am hauling my camper and towing my ATV trailer but that is not going to happen but those only make up maybe 25-30% of the overall miles on the truck so I don't really care too much about that.
I had a 2000 SD with the 7.3 and while it would out pull the 6.2 which I would expect it to being a diesel, I will take this truck any day of the week.
#81
Just voicing a preference. Advantages and disadvantages are always in the eye of the beholder. I just want my 7.3 in my 6.2's chassis. I like the diesely character without the downsides that come with an outdated chassis (in my opinion) or without the cost and complexity of a 6.7.
I know its never going to happen, but I can dream.
Steve
Steve
#82
Chris 42163 is correct regarding power; it's work per time.
"Horsepower" is a somewhat silly, arcane term, but we all recognize it and what it infers. HP is merely a statement of torque at some applied rpm; nothing more or less. Many of us know the formula .... HP = (Torque x rpm) / 5252.
The "5252" is a constant that represents the conversion from "revs per minute" to radians per second. It's a means of converting UoM (units of measure) to account for rotation. HP is an attempt to describe "work" in the rotational sense, over a duration of chronology.
https://auto.howstuffworks.com/question622.htm
Torque of the engine is multiplied by the trans gears and the diff gears. That torque is then turned into "force" (mass x acceleration) at the road surface when you take the torque at the output axle and then correct for wheel radius at the contact point on the road. This gives you a thrust force that actually propels the truck forward. Despite what many folks think, Torque is a form of work, not power. Read on ...
"Work" (in real definition of physics) is simply this: W = F x D, or work is force x distance. If two trucks with different engines (6.2L vs 7.3L) pull 10,000 pounds up a 500' incline, they both did exactly the same amount of "work" because they moved the same load for the same distance. The type engine does not matter in a real "work" formula.
- work in a linear fashion is this: force x distance (example shown above; you move 10,000 pounds up 500 feet of incline, you've done 5,000,000 lb-ft of work).
- work in a rotational fashion is still this: force x distance, but uses the term "torque" (example ... a wrench that is 2 foot long and has 100 pounds of force applied develops 200 "ft-lb" of work potential).
- because "work" is a multiplication mathematical formula of force x distance, you can use either term because the formulation does not alter the output (ie ... "ft-lb" or "lb-ft "are both proper terms because "a" x "b" is the same at "b" x "a")
- There are two types of work; potential and realized. This is what confuses a lot of folks especially when it comes to rotational work (torque). An engine spinning at 1,000 rpm may make 200 fl-lb of torque. But if I put 100 pounds of force on a 2 foot wrench, I'm still making 200 ft-lb of torque. One is in motion and the other is potential, but they are BOTH the correct expression of force in rotational effect. The torque made by the engine (200 ft-lb) is no more or less than the torque applied to the wrench (200 ft-lb).
"Power" is how fast work gets done. Power is work measured over a standard of time; Power = work/time. Or we can input the force formula into the power formula .... Power = (Force x distance) / time.
One truck can be more "powerful" than another, depending upon how quickly it can do the work. If the two trucks in the example above still pulled that 10k pounds up the 500' incline, but one truck got there faster than the other, then it would be more "powerful" because it took less time to do the same work.
Ahhhhh .... high school physics. I knew it would come in handy some day.
#84
#85
True, but you've changed the inputs and so the output is understandably changed. You mod a 7.3PSD and it will out-pull a stock 6.2 gasser.
The 7.3L already has a stock power-adder; a turbo. So you modify the injectors, the ECM programming, etc and viola .... more torque from the diesel.
But what happens if you mod a 6.2L? You can re-balance the equation.
How about we add a blower or turbo to the 6.2L and retune the gas ECM and see where we're at?
Apples to apples; that's the fair way. A stock 6.2L essentially can pull what a stock 7.3L can pull.
#86
How about we add a blower or turbo to the 6.2L and see where we're at?
#87
Received 3,090 Likes
on
#88
I'm not sure what prompted the physics lesson, and I am getting more and more impressed as people really are starting to understand the difference more than they used to. However, this statement is false. Torque, while sharing a similar unit notation, is in no way work. It's a force applied at a distance about a fixed axis. It's best to think of it as rotational force, but just as linear force is not linear work, neither is torque rotational work. Linear force applied over a distance is work. Torque applied over an angle is rotational work.
#89
This discussion of modding a 7.3 to pull more kind of misses the point for me. The power is not the limiting factor on the gen 1 PSD. My guess is that the factor limiting GCWR to 20k lbs is probably the brakes. I know there are passionate enthusiasts here who like to race another truck while pulling a load up through the Rockies, but that's just not me. I'll drop a couple gears and be happy trucking right on up any interstate hill at 60 mph at the top of 3rd (ZF6). The important parts to me are reliability, which modding doesn't help, fuel economy, which modding (not even tuning) doesn't help, longevity, which modding doesn't help, and safety, which modding can help (exhaust brake, OL springs, brakes, wheels/tires).
Now, to entertain the modding discussion to some extent, I'll have to side with the 6.2 again. In safety of stock form, it's putting down 150hp more than my 7.3. Yeah, a chip and a couple minor mods can get me there, but am I going to be comfortable putting all that power down going up a steep grade under load? I don't think so. Mine is stock, but I'm of the understanding that the pyrometer starts heating up pretty quickly when it's under that much strain. No thanks, in stock form I can mat the throttle all day without a worry, as long as I keep the RPM up. When I bought the truck and pulled nearly 20k lbs gross, I was worried about doing that through the Mountains, but the concern was not warranted, because I've gone through the Rockies and Appalacians pulling 17-20k lbs a few times, and have never wished for more power.
#90
Another thing between the 6.2 and the big V8 diesels: look under the hood of each. Observe that there is NO room in the space around the engine with the V8 diesels to be able to work on anything. It's all just jam-packed in there and of course on the old 7.3s, the cab had to be lifted to do anything to the injectors or turbo etc. What a pain. Now look under the hood of a 6.2 and wow! What do you see? That's right, plenty of room all around the engine for access to everything. Sweet! And BTW no exhaust gas recirculation. For anyone who does their own basic maintenance, the 6.2 wins hands down.
