Tire size and gearing question?
35" It would come out to 4:07.36
37's would come out to 385.34
https://tiresize.com/gear-ratio-calculator/
So it should be somewhere between 4.1 and 3.99. Would think I would be ok with that. My last truck had 3.73's and that thing was a pooch! This is my work truck and a normal load for me is around 2500lbs of tools, fuel and DEF fluid in my tool boxes and auxiliary tanks. I pull skidloaders and a mini excavator at times, but not all the time. This truck is leaps and bounds nicer to drive than my 2011!! I don't want to loose the drive ability of this truck but it definitely needs bigger tires to fill the giant wheel wells!
I pull about the same as you but not daily, I stuck with the 18" because I like more sidewall showing and went with 295-70-18's 34.4" but the load range is 4080 Lbs which was also Important to me. Put me at 416.16. I couldn't see the 1/4" difference in height. Load range was more Important.
I tow my CTL and mini excavator's too. I just chose to go back to the 295/70/18 in place of the 35/1250/20's I had been running. I just want to gain a little more back out of the 6.2. I too went with the Michelin Defender's which are a lighter 10 ply rated tire at 4080 lbs. I am very happy with the switch. The 295/70/18 is a great size that offers the high 4080lb load rating, and fills the wheel well especially with aftermarket wheels.
Humbucker427
2017+ Super Duty
03-12-2017 11:49 AM
StanleyZ
02-18-2009 12:51 PM
racsan
1983 - 2012 Ranger & B-Series
20
10-13-2007 05:56 AM
