Installed Mishimoto Radiator - Leaking Transmission Everywhere
Finished installing a Mishimoto radiator in 92 7.3 today. Everything went smoothly. Reconnected all the lines, started the truck, backed out of the garage and saw a trail of transmission fluid.
The fittings for the transmission lines are as tight as I feel comfortable getting them given that they're aluminum. I feel like I'm missing some o-rings or something, but I can't find anything suggested that those should be used and they weren't included in the shipment from Mishimoto.
Anyone else have this experience? I've got this whole weekend to mess with the truck and would rather not wait until Tuesday to chat with Mishimoto support.
well if there are not orings on those fittings and they are threaded, I would think just remove them and coat with 2-3 wraps of teflon tape and a light coat of TFE paste over the teflon tape, then thread it back in, teflon tape and tfe paste need no cure time, in fact its best to go ahead and try it out after you put it together. the pressure will settle the tfe paste in the rest of the way if needed.
hopefully you got this sorted out, but if not then I hope this helps.
Just started leaking coolant again, right after I switched to CAT red coolant. Looks like a cracked radiator, but haven't gone underneath to check it out yet. Is Mishimoto about my only choice for an aluminum radiator? Anyone used the new coolant expansion tank they carry?
You can also get an aftermarket radiator for our trucks from Champion. I've heard they have questionable quality though. FWIW, I installed a parts store cheapie in my truck and it works great. The biggest plus is that it has a lifetime warranty.
https://www.championradiators.com/products
I believe the seals in these engines aren't compatible with that coolant, and the original radiator might not be also. I've repeatedly read that some modern coolants don't play well with the soldered radiators.
I didn't hear about it from anything to do with IDIs, it was when researching coolants for various applications. There was something about long life coolants either attacking or just not protecting the solder in radiators. It was said that this was the main reason that manufacturers didn't use long life coolants with them. I remember something about some manufacturers doing it before knowing and having a ton of issues, then going back to 'normal' coolant. I still run old school coolant in all my stuff that has a soldered radiator just in case.
More recently when researching coolants for my 7.3 PS similar stuff came up about different year models and the compatible coolants. While it might be BS, the video I watched was done by a supposed coolant expert that talked about different year powerstrokes and which coolant was ok in which years. He specifically cited issues with seals used in the different years and which coolants were safe for them.
The only benefit I see the the elc is the supposed 500k service life and the sca's already added.
Personally I wouldn't want to keep anything in my system for that long. Every two years I flush mine out and go with new. We've had the green coolant since I can remember and I don't ever recall it being a problem with anything other than the lack of sca's and that's just an engineering fault, 7.3 cylinder walls should have never been that thin, and even so cavitation is rare.
I blame it on the people that just run water. I've seen all kinds of thermostat housing and water pump cavitation from it. Holes in stuff 1/4-3/8 of an inch thick.
Most machine shops will just bore it and stack a sleeve in there, with varying results I might add.
Most times they'll drop and hit the crank within a 100k or 2 and the cranks toast at that point as well as the block. I'm curious to see what the lifespan of Justin's 6.9 sleeved 7.3's are.
Most times they'll drop and hit the crank within a 100k or 2 and the cranks toast at that point as well as the block..
And the lack of SCA was Ford's fault, other than Ford pickups, any International truck that had a 7.3 in it came factory equipped with a coolant filter that released SCA.
pimpedrsrage
1999 to 2016 Super Duty
08-03-2012 11:09 AM
Bobseaweed
1983 - 2012 Ranger & B-Series
08-13-2007 08:35 AM
acheers
04-16-2003 01:04 PM
