C4 Corvette Rear Sway bar mounting
Hey all. For those that have put the C4 Vet rear suspensions in what have you done for the sway bar? I put my bed back on the other day and found that the sway bar was hitting the bed. Not sure how I missed that as now I look at it and it was pretty obvious that it was gonna be an issue.
But none the less. Have any of you run into this? I did not tub the bed. I widened the fenders instead. FYI
Yeow that is a tight fit...the last one I did had tubs so that clearance was not so critical. Is there any way to incorporate the heim knuckle into the end of the sway bar/torsion arm so that you could eliminate the riser at the hub? Those hubs have a very stable up/down vertical travel with little front to back motion...the only movement in that direction would be due to the arc of the sway bar. You might be able to get away with only one heim joint at the hub attachment point.
Voodoo66
04-24-2009 06:48 AM
