You might try pulling the Trailer Battery Charge relay and see if the fuse still blows.
Ok, I've pulled that. Still blows the fuse if I jumper #6 & #7.
I pulled the 15 pin bulkhead connector from the firewall that has the Black/pink wire. It shows continuity from there to the 5 pin connector at the rear of the truck.
I wired the backup lights directly to the positive side of the battery. I have 12.5 volts at the 5 pin connector at the rear. So I know the wiring is ok there.
Could there be a problem in the ignition switch?
I checked for continuity between the 5 pin connector at the rear to the steering column and it's good.
What I don't understand is why #6 and #7 blow fuse E when jumpered. I literally can't find a short in all the wiring.
Next question, where do you find a "15 pin bulkhead connector"?
You should have two bulkhead connectors a C202 (76 pin connector) and a C205 (24 pin connector).
It the C205 connector. There are only 15 pins used out of the 24. Sorry for the confusion.
I connected the TR sensor, with Reverse selected, I have continuity. Its showing good with no high resistance. As soon as I apply power and turn the key on, it blows the fuse but only with Reverse selected.
