1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front end fell in water, need advice
Old 09-01-2017, 10:37 PM
Esoj's Avatar
Esoj
Esoj is offline
Long story short the front end of my 2013 F250 6.7 4x4 was driven into a small pond of muddy water. Truck lasted total of around 10 seconds in, had to step on the pedal a bit when it was in reverse to get out. Checked the oil and transmission oil and both didn't seem to get any water. Truck seemed fine for a bit until it idled for about 15 minutes and them shut off when put into drive. When i drove the truck on the empty street it would not pick up higher than 60 mph and the transmission shifts were out of tune. When truck was parked it would shake a little bit and now if i turn it on and run it it seems to overheat and turn off. Any ideas what it could be, gonna lift it up and change all oils tomorrow including the differential oil. Any insight would be appreciated
Old 09-02-2017, 08:07 AM
redford's Avatar
redford
redford is online now
Received 1,549 Likes on 904 Posts
Do you have a CEL?
Old 09-02-2017, 10:00 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
over heating is probally mud in the radiator fins
all your electrical contacts are probally wet...with some now having fine grit in the contacts from the muddy water
depending on how deep tht water was....your alternator could have been submerged
if 4wd, front axle might have taken somewater
also depending on how deep, transfer case and tranny could be effected
if you have comprehensive insurance, maybe your insurance company will cover a dealer deep dive and repairs
Old 09-02-2017, 10:12 AM
alloro's Avatar
alloro
alloro is online now
Received 4,174 Likes on 2,419 Posts
How high up the truck was the water?
Old 09-02-2017, 05:41 PM
Esoj's Avatar
Esoj
Esoj is offline
With everything going on didnt exactly take a good look but it did go up a ways
Old 09-02-2017, 08:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
I don't know what you did but I've sunk the front of trucks entering a new mud hole so it won't over the hood and halfway up it! Slammed the truck in reverse and powered out....never had an issue. So what happened really? LOL
Old 09-02-2017, 09:29 PM
firebirdparts's Avatar
firebirdparts
firebirdparts is offline
Didn't you read? The water went up "a ways" for "a while".
Old 09-02-2017, 11:02 PM
Tofan's Avatar
Tofan
Tofan is offline
Call insurance company, no need to even talk about this even further.
Old 09-03-2017, 07:04 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Flush all the electrical connectors out or there will be gremlins for years.
Old 09-03-2017, 08:06 AM
Leon82's Avatar
Leon82
Leon82 is offline
Unplug the connectors and make sure they are dry.
Old 09-03-2017, 09:39 AM
alloro's Avatar
alloro
It's hard to estimate what could be damaged without really knowing what got wet. For example, there is a vent hose for the front axle and as long as that vent did not take in water the front axle is fine.
Old 09-03-2017, 03:50 PM
SuperDutyScaler
Check the COP to see if water got down into the spark plug hole
Old 09-03-2017, 05:57 PM
Esoj's Avatar
Esoj
Esoj is offline
Originally Posted by redford
Do you have a CEL?
Truck has always had the CEL on so wouldn't know if it did, will probably check for any codes later
Old 09-03-2017, 06:01 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Did your air filter take in water past the filter?
Old 09-04-2017, 11:29 AM
Esoj's Avatar
Esoj
Esoj is offline
I removed the air filter the day of the incident and you could see puddles in the squares at the bottom of the air filter box so my guess would be yes
Quick Reply: Front end fell in water, need advice
