52 gauge cluster glass seal - Ford Truck Enthusiasts Forums
Old 09-01-2017, 09:14 PM
3twinridges's Avatar
3twinridges
3twinridges is online now
3twinridges has a good reputation on FTE.3twinridges has a good reputation on FTE.3twinridges has a good reputation on FTE.
I took the gauge cluster apart tonight for a good cleaning and polish. The glass had a rubber type goey gasket that kept me from totally cleaning the glass. Any thoughts on a good way to seal up the gauge cluster after I clean the old seal out of the groove?
JB
Old 09-06-2017, 05:48 PM
Mrln45
Mrln45 is offline
Mrln45 is starting off with a positive reputation.
I'll try the buffing wheel, thanks.
Old 09-06-2017, 11:52 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is online now
Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.
I have had a few sets apart and all of them had a thin cork gasket.
Old 09-07-2017, 08:11 AM
Mixer man's Avatar
Mixer man
Mixer man is online now
Mixer man is a splendid one to beholdMixer man is a splendid one to beholdMixer man is a splendid one to beholdMixer man is a splendid one to beholdMixer man is a splendid one to beholdMixer man is a splendid one to beholdMixer man is a splendid one to behold
I would use duct seal. Available at most hardware stores.
RectorSeal® Duct Seal Compound - RectorSeal
Old 09-07-2017, 11:32 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I would think anything at all soft will eventually ooze some plasticizers when exposed to heat. Cork sounds like a safer bet.
Old 09-07-2017, 02:02 PM
Mixer man's Avatar
Mixer man
I have used duct seal in a wide variety of applications including hot air HVAC air handlers. It doesn't bleed out at high temps of around 150°F. It doesn't "age" like gaskets do. I have also used it for potting electrical components.
Old 01-03-2018, 07:26 PM
3twinridges
I picked some large o rings from mcmaster that are going to work nicely on the glass seal. But when taking it apart this piece of tape fell off the back hole, which I assume is a dust shield that used to let light in from the bulb. Any thoughts on what to use on that hole? Clear packing tape?
Old 01-03-2018, 07:45 PM
Mixer man's Avatar
Mixer man
Could it have been the red filter for the high beam indicator?
Old 01-03-2018, 07:48 PM
3twinridges
No that is on the speedo unit with the two turn signals arrows. This is on the gauge cluster.
Old 01-03-2018, 08:56 PM
DocMSavage
DocMSavage is offline
DocMSavage is starting off with a positive reputation.
seal
The two I worked on used a thin cork gasket, I bought a roll online and made mine. I have some left if you need it. It worked great. PM me if you want pictures of the gauges and the cork roll...
Doc
Old 01-11-2018, 08:16 PM
'51 ford f1
'51 ford f1 is offline
'51 ford f1 is starting off with a positive reputation.
Used cork tape on mine, use it in HVAC sealing, but can take apart, comes in a roll.
Old 01-11-2018, 08:19 PM
3twinridges
Thanks, any thoughts on that tape over the hole? Think I would be ok using a piece of packing tape over it? It's the hole where the light from the bulb behind it illuminated the gauge faces.
JB
Old 01-11-2018, 08:40 PM
abe's Avatar
abe
abe is offline
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
JB
Try it. If it doesn't work right, or look right, take it off.
Old 01-11-2018, 09:53 PM
cowdog86
cowdog86 is offline
cowdog86 has a very good reputation on FTE.cowdog86 has a very good reputation on FTE.cowdog86 has a very good reputation on FTE.
I used plummers putty rolled really long and thin for the glass seal. Excess was just trimmed off.
Maltman
108
05-05-2018 01:47 PM
firstrider
10-25-2017 02:44 PM
3twinridges
09-06-2017 04:08 PM
William
Ford Truck Parts for Sale
04-14-2016 06:10 PM
Scotty's 52 F3
03-24-2016 01:47 PM
Quick Reply: 52 gauge cluster glass seal
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
