400 Build Advice
#32
on
I really don't know much about engine building, so that's why I asked about the lube/oil.
Maybe someone else will chime in and clarify?
#33
I have always used engine assembly lube on the bearings. That's what it is made for, and it doesn't run out when you let the engine sit for months. But, on the cam and lifters I use a cam lube, which is also somewhat thick and doesn't run out like oil. Both are designed to dilute in oil and not be a problem.
And, I also pre-lube the engine just before firing it up by pulling the distributor and spinning the oil pump using a socket on an extension and my drill. I spin it until I hear the drill start working hard, which means I have oil pressure, and then I spin it several more seconds to ensure the oil gets to everywhere.
#34
#37
I will keep this thread updated. I plan to park the car by the end of the month, then will start working on pulling the engine.
I just did mine
Tims pistons .030 over
had rods reconditioned and whole assembly balanced
(well worth the $250 ) to have done
comp cam
Cam/Lifter, Valvetrain, Hydraulic Flat Tappet, Adv. Duration 255/263, Lift .465/.495, Ford, 351C, 351M, 400
standard rebuild on my 1971 heads new guides, seats & valves
edelbrock performer 400 intake
summit 600 cfm carb
dual exhaust on my iron manifolds
idles smooth, (no lope ) throttle response is fantastic
and pulls my marquis like a FREIGHT TRAIN !!!
comp cam
summit 600 cfm carb
I am assuming you have a 1971 Mercury Marquis? What gearing do you have in your car? How does it compare to the stock engine powerwise?
#38
#40
#45
Kyle Wood
04-06-2017 05:43 AM
72fordgts
11-06-2014 01:49 AM
