1966 f100: 3.54 to 3.00 Ring & Pinion
Hello,
I'm looking for better highway top speed and want to swap my stock 3.54 ring & pinion gears for 3.00. However, my mechanic says the new 3.00 gears from Motive Gear (from Summit Racing) won't fit (too small). Will you guys give me a second opinion? And if he is right, then is there an alternative source that will work?
Thanks,
Edward
Attached are pictures. Differential tag states: "C6Ta-AY 3.54". I just had the 352 rebuilt and the 4 speed tranny.
Thanks,
Edward
That number decodes to the Dana 60.3 in the 1966 F100. It was one limited slip option at the time since the 9" wasn't available in LS in the trucks in those years.
I'm not positive if they can help, but give these guys a ring (no pun intended) and see what they can tell you. Make sure you tell them it is a Dana 60.3, not the average Dana 60.
https://www.ringpinion.com
Chad
Chad
That's interesting. I've never seen a 60-3. The 60-2 has "60-2" cast in the top of the housing in letters an inch or so tall. You can see the markings in the truck with a light and a mirror. Does the 60-3 have such numbers cast into it?
Chad: Wasn't the Dana 44 also available in a limited slip? (Not that it would help Edward too much, the best ratio is a 3.31.)
Hello 1972RedNeck,
I check with Summit Racing and this was their reply: "Thank you for the email. I do not have any 3.07 ring gears listed for your axle."
I also contacted Randy's Worldwide (ring & pinion) a couple times, but haven't heard back from them.
Do you have any recommendations for where I can find the 3.07:1 gears you mentioned that will fit my truck? I'd greatly appreciate it.
Thank you!
Thank you!
Hello 1972RedNeck,
Thank you!
Thank you!
Give National Drive Train a call as well. I just finished replacing the R&P in my Dana 44 and they were very helpful. The gal I talked to was familiar with the fact that there are 60.2s and 60.3s out there. Good luck if you do rebuild it yourself. On mine, all seemed to go well, but I could tell something isn't right as I drove around the block.
Now I have a question for all the guru's such as ND and TA455 and the rest of you. Is the 60-3 the same as the 60-2? From the pic it looks like it is on the outside, But internally would the 3:54 gears from a 60-3 work in a 60-2? And if the answer is yes. Corequality would you be willing to part with you 3:54 ring and pinion if you find another set?
