1966 f100: 3.54 to 3.00 Ring & Pinion
Old 05-24-2018, 12:15 PM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Originally Posted by skidoorulz View Post
Now I have a question for all the guru's such as ND and TA455 and the rest of you. Is the 60-3 the same as the 60-2? From the pic it looks like it is on the outside, But internally would the 3:54 gears from a 60-3 work in a 60-2? And if the answer is yes. Corequality would you be willing to part with you 3:54 ring and pinion if you find another set?
Going to 2" taller tires will effectively change your 3.54's to 3.33's. This is a lot easier and probably less costly than regearing the rearend. Just something to consider here. And if you don't like the result, it's a lot easier to undo.
Old 05-24-2018, 08:05 PM
skidoorulz's Avatar
skidoorulz
skidoorulz is online now
skidoorulz is starting off with a positive reputation.
I have 4:10's and want to go to 3:54's
Old 05-24-2018, 09:45 PM
baddad457
What size tires are you running now ?
Old 05-25-2018, 12:26 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
Backyard Project Manager
Boss9F100 has a great reputation on FTE.Boss9F100 has a great reputation on FTE.Boss9F100 has a great reputation on FTE.Boss9F100 has a great reputation on FTE.
In my Dana 60 I upgraded the ring and pinion along with axles to current standards. Randy's world wide is a great place to buy. They do have a online configure page.
https://www.randysworldwide.com/diff...RWD&diffid=148
I also went with late model 6 spd auto
I have a T-85N R-11 3spd overdrive in my other 66 and absolutely love it. I am running 35 MPG per 1000 RPM. 3.54 not a bad gear with fairly tall tires. I installed 2017 F250 wheels on my 1966 F250. A much better tire selection. Its easy to swap back to the stock wheel if need be.
I am running 255/55R-18's on all four corners. Had that same size on my other 1966 F100 and really liked the ride and handling.
Old 05-25-2018, 06:24 AM
baddad457
2" increase in tire diameter gets you to 3.86 gear another inch brings you to 3.74
Old 05-25-2018, 09:20 PM
skidoorulz's Avatar
skidoorulz
Well there is another problem with 2 inch taller tires. Truck won't work in my trailer. I have about 3/4 to an inch clearance at the top of my door to the top of the frame on the escape door on the trailer. If I go to a taller tire I will not be able to open the door on the pickup and get out.
Old 05-25-2018, 09:58 PM
baddad457
2" taller tires lifts the vehicle 1". Let a few pounds out and that'll lower it.
wbuffetjr1
Ford Truck Parts for Sale
05-31-2011 02:53 PM
f100ingo
07-16-2009 10:33 AM
e william
02-20-2006 08:49 PM
TommyLee
32
01-23-2004 11:32 PM
Chuck
01-05-2000 08:19 PM
Quick Reply: 1966 f100: 3.54 to 3.00 Ring & Pinion
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
