Tow package vs Non tow package radiator size
I own a 2013 SCREW 4x4 5.0 without a tow package and have read that a truck with the tow package comes with a heavy duty radiator....I know that this was definitely the case in the 90s since my 93 Bronco has a radiator thats very noticably thicker than many of the other 90s Ford trucks I have seen and came with an aux tranny cooler. However I did take that into consideration when I bought my F150 because I knew I wanted the biggest radiator offered since I could potentially be towing my bronco with my F150 down the road. So when I went on the hunt for my F150 I found my current truck online and went with a buddy who owns the same truck as me except a 2012 with a tow package. After I looked the truck over and took it for a test drive I had noticed the truck did not have a tow package but knew adding a TBC and a tranny cooler was no big deal so the main thing I was concerned about was have a smaller radiator than a truck with the tow package, so in order to ease my mind I walked over to my buddies 2012 with a tow package and popped the hood and sure enough the radiator looked to be the same size as the truck I was about to buy so here I am 10k miles later wondering how did I end up with a weaker radiator?
So my question to you ladies and Gentleman is if the physical size between a tow package radiator and a non tow package radiator isn't the difference then what is?
The towing package does have a different radiator, but im not sure of the actual differences.
I have not heard if anyone having cooling problems by not having the upgraded radiator. If it were mine, I'd run it as is and if cooling became a problem I'd simply upgrade the radiator to the one that comes with the towing package.
You can get an aftermarket factory style transmission cooler very reasonable online.
http://www.partsgeek.com/gbproducts/...ad=47584901292
chackett
05-04-2015 03:31 PM
ruthless
05-27-2002 01:47 PM
