i also use a cd magnetic mount for my android phone. over 7200 miles this summer, across 45 days, and 20+ separate drives, the rough roads shook the phone loose every drive at least once.
Are you running 80 psi? I run 65 because it's just too rough at 80.
75 up front, 65 in the rear.. also airbags on the rear. and a Trailaire Triglide pinbox on the trailer
Yea this type of mount does get a little squirley on rough roads, I'll probably experiment with some different types of mounts to see if I can find a better solution.
