2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Ordered 2WD Valence
Old 05-10-2018, 05:15 PM
Kbryant's Avatar
Kbryant
Kbryant is offline
Ordered 2WD Valence
Tried to use search function and couldn’t get any good installation info. Any tips from those that have done this? What about the Prius catchers? Do they remain or do you remove and pitch them? Advice appreciated!
Old 05-10-2018, 05:27 PM
cficare's Avatar
cficare
cficare is offline
I searched this forum for "2wd AND valence" in titles only and found this ... https://www.ford-trucks.com/forums/1...ence-part.html
Installation is about as simple as they come. Unbolt old & bolt on new (19 small bolts IIRC).
Prius-catchers? That's your decision. I left mine on and they're not that noticeable.
Old 05-10-2018, 05:29 PM
S cobb's Avatar
S cobb
S cobb is offline
There’s a lot of bolts. I trimmed mine while on the truck no problem. Taped a line used a cut off wheel. Looks prefect
Old 05-10-2018, 06:47 PM
bigspeedy626's Avatar
bigspeedy626
bigspeedy626 is offline
Easy to install. Takes 10 minutes to remove and 10 minutes to install the new one. Make sure you use impact driver to make the installation easier.
Old 05-10-2018, 06:54 PM
MNSuper's Avatar
MNSuper
MNSuper is offline
I cut mine myself. Remove the Prius catchers (total of 8 bolts) and ran this Dremel circular saw along the bottom of the bumper. It was done in minutes. Ignore the tape. My original plan was to draw a line where I wanted to cut but using the bumper as a guide was way easier.
Old 05-10-2018, 07:11 PM
Kbryant's Avatar
Kbryant
Kbryant is offline
Do the Prius catchers extend below the bottom of the new (2WD) valence?
Old 05-10-2018, 07:37 PM
cficare's Avatar
cficare
cficare is offline
Yes, but I left them with the idea that if I ever do run over a "Smart" car, I don't want the additonal liability from having removed a potentially life-saving feature.
Old 05-10-2018, 08:02 PM
Kbryant's Avatar
Kbryant
Kbryant is offline
Is there true liability with those things? Are they mandated by law or “best practice”?
Old 05-10-2018, 08:09 PM
cficare's Avatar
cficare
cficare is offline
I honestly do not know ... and I hope I never have to find out,too
Old 05-10-2018, 08:17 PM
BillyE's Avatar
BillyE
BillyE is offline
I removed my Prius catchers. They were pretty obvious with the 2wd valance. As I recall there is one bolt on each end of the balance that is hard to get to. I think the whole deal took about an hour. I removed the small bolts with an air ratchet but tightened them by hand for fear of stripping the inserts. IMO this made a big difference in how the front end looks.
Old 05-10-2018, 08:45 PM
flatlander2441's Avatar
flatlander2441
flatlander2441 is offline
Old 05-10-2018, 08:59 PM
Truckie256's Avatar
Truckie256
Truckie256 is offline
^^^^^^^ watch this Video....^^^^^^^
University of YouTube
Old 05-10-2018, 09:06 PM
Cohlmeyer's Avatar
Cohlmeyer
Cohlmeyer is offline
Super easy install takes just a few minutes. The Prius are an eye sore, they are longer than the 2wd valence.
Makes a big difference I think
Old 05-11-2018, 06:34 AM
7591250sd's Avatar
7591250sd
7591250sd is offline
could you post a pic please? how much did you trim. thanks
Old 05-11-2018, 06:42 AM
rbraughn's Avatar
rbraughn
rbraughn is offline
I want that Bronco in his garage!!
Quick Reply: Ordered 2WD Valence
