AC randomly stops working
About a month ago, I was driving 50 mph in my 06 screw on a dirt road. There was an old wood bridge that was not as flush as I was expecting. Jolted the truck pretty good but it kept on trucking. However, a few seconds after the jolt, the power to the AC cut out. All I had to do was turn the AC to "off" then back on and it'd start working fine. Over the last month, the power randomly cuts out, but will go back on after I switch to "off" then back on. It's happened maybe 3 or 4 times since The Big Jolt.
Any suggestions for a fix?
You have a clutch relay in fuse box on drivers fender
My relay went intermittent , parts house has generic relay . Clean contacts on clutch plug both sides .
https://www.f150forum.com/f4/20o5-ac...-relay-370228/
VA250SD
05-12-2012 11:58 AM
JIM ROLAND
60
06-12-2010 09:23 AM
