Finally got the other side floor pan welded in and ground smooth. I also seam sealed all the joints. Now to shoot some epoxy primer. New to me so I'm apprehensive.
looking up at the roof I see you have a couple of holes to patch. the po of my truck had an antenna or something mounted in the roof so I have a 1/2" hole to weld up also.
**edit** nevermind, I see those are running light holes in your roof. this is what reading threads with no sleep does
