67 F-100 4x4 restoration - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-07-2017, 11:47 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Originally Posted by mrpotatohead View Post
A lot of the problem for me is the terminology:
There are upper and lower rubber mounts, inner steel sleeves, washers, nuts and bolts. What's a retainer?
The retainers are the upper and lower sleeves. None of those two retainer part numbers are on my locators. I wonder if Dentside ones would work?
  #32
Old 09-07-2017, 11:52 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Never thought of that, Jeff. Do they use the same type of retainer?
  #33
Old 09-07-2017, 12:08 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Different part numbers. On a Dentside the upper retainers (sleeves) come in the upper mounts. The lower sleeves have a nut attached to them. So they are a sleeve, washer, and nut assembly.
D4TZ1000157D......Cab mounts.
D4TZ1000157C......radiator support.
Here is a pic I found on g**gle of the "C".
  #34
Old 09-07-2017, 12:15 PM
67nukeford's Avatar
67nukeford
Have to check the thickness, but, those just might work!
  #35
Old 09-07-2017, 04:22 PM
mrpotatohead
mrpotatohead is offline
mrpotatohead is gaining momentum as a positive member of FTE.mrpotatohead is gaining momentum as a positive member of FTE.
Cab mounts. The front mounts are the same on both 2wd and 4x4. The rear mounts on the 2wd are thicker than the 4x4 mounts.
Thanks a bunch for the clarification. With my thick skull and old mans disease I am a little slow sometimes. Thanks again Nuke and you too Jeff. Oh by the way, I bought a 66 F-100 custom cab today that is disassembled but the body is almost flawless. The best part is the price: 400.00! I'll post pictures tomorrow.
  #36
Old 09-07-2017, 04:43 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
$400 !?!? Wow. Congrats.
  #37
Old 09-07-2017, 04:44 PM
cstoyer's Avatar
cstoyer
cstoyer is offline
cstoyer is starting off with a positive reputation.
I had to buy the 2wd set, and have them cut down in the rear. For the life of me, I can't figure out why they don't sell a 4x4 set.
I purchased a set of absorbers from Prothane for my cab and core support on my f250 4x4. They matched what came of the truck for height and diameter. However, I was lucky to be able to use the retainers from my old mounts because as nuke said you can't find them or mod the 2wd ones.
cstoyer
  #38
Old 09-07-2017, 10:53 PM
mrpotatohead
cstoyer
Ok, thanks for the additional information
  #39
Old 09-08-2017, 08:25 AM
67nukeford's Avatar
67nukeford
cstoyer
Yeah, I saw those, but, my retainers were toast! I wish someone would repop those damn things!
  #40
Old 09-09-2017, 06:08 AM
mrpotatohead
My body cart
Here's a couple of pics of my body cart I made. It's large enough so that I can tilt the cab on it's back to address the underside.
  #41
Old 09-09-2017, 06:13 AM
mrpotatohead
Here's the first pics of my 66 F-100 custom cab I bought the other day.
  #42
Old 09-09-2017, 07:37 PM
RichS2659
RichS2659 is offline
RichS2659 is gaining momentum as a positive member of FTE.RichS2659 is gaining momentum as a positive member of FTE.
Nice find. A lot of fires happening now? Where did you pick it up at? It looks like south of Nampa close to the river.
  #43
Old 09-09-2017, 08:00 PM
mrpotatohead
You guessed it. It was out on Sommercamp road south of Marsing. All that smoke you see is from Oregon fires they say.
  #44
Old 09-10-2017, 10:11 PM
mrpotatohead
Time to order some sheet metal!
The payoff of the work table is when you can effortlessly access the underside.
I almost needed both hands to tilt this thing back.
  #45
Old 09-11-2017, 03:23 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
That is a very nice cart you made. Looks to be a great working height as well.
Quick Reply: 67 F-100 4x4 restoration
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
