That firewall looks great. I like the lighter color idea. That primer looks like tough stuff. Great work. I'm with Teach- it's too cold here to apply anything- it's been from 5 to 25deg here.
I used Omni mp 282 2k hi build primer surfacer with mp283 hardener. Got about half of the cab sanded down today with 320 grit. After that's done I'll do some spot puttying, spot spray with hi build and then sand it all again with 400 grit and then will hopefully be ready for final painting.
Yep that stuff gets pretty hard. The longer it cures the harder it gets too. While you’re wet sanding,use a rubber squeegee or bonds spreader to wipe away the sludge. If you see heavy scratches, follow the 400 wet with 600 wet.
Thanks, I ordered 800.00 worth of interior insulation, sound deadener, and a firewall cover. Don't tell my supervisor! For anyone thinking about trying one of those cheap firewall covers off of e-bay, don't! I bought one and the holes are wrong among other things. I'm sending it back. I've spent too much time and money on this restoration so far to start making it look substandard now with cheap parts.
