58 F100 Front and Rear lower shock mounts.
Hi All. Looking for pictures and maybe point me in the right direction for the front and rear lower shock mounts for a '58 F100. Uppers are there. Truck didn't have them when I bought it. I did an axle over springs conversion on both front and rear and realize I will have to do some fabrikatin' but I need a place to start. Here is a link to my thread.
https://www.ford-trucks.com/forums/1...e-to-here.html
If not, you will need them and the stud that retains the rear shock absorbers to the brackets.
Previous owner removed them when they added the extra leafs. it was a farm truck and they jest ran without shocks. I am hoping to get both front and rear original brackets. I don't want to buy aftermarket. If they are not available, I'll make my own. I did an axle over spring swap on both axles with the u-bolts now inverted and once I get the brackets, I intend to fabricate brackets so I can bolt the originals in place and use original length shocks. Browsing the internet, I see 3 different styles.
1957/60 F100/250 2WD:
B7C-18126-A .. Right Front Lower Shock Absorber Mounting Bracket / Obsolete
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
B7C-18127-A .. Left Front Lower Shock Absorber Mounting Bracket / Obsolete
KAMA OBSOLETE PARTS has 1.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
1957/58 F100:
B7C-18132-A .. Right Rear Shock Absorber Mounting Bracket / Obsolete
No Ford dealer or obsolete parts vendor has any.
B7C-18133-A .. Left Rear Shock Absorber Mounting Bracket / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 2 = 701-523-3257.
1956/58 F100/250; 1959/60 F100/250 4WD; 1959/60 F250 2WD:
2) B6C-18193-A .. Right/Left Lower Rear Shock Absorber Mounting Stud / Obsolete
CARPENTER NOS OBSOLETE PARTS has 1.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
1957/58 F100:
1957/58 F100:
1956/58 F100/250; 1959/60 F100/250 4WD; 1959/60 F250 4WD:
1957/58 F100:
