56 panel truck fuel tank solutions
on
I'm just assuming that the frame rails on a panel are just like the trucks... lots of guys put the Mustang tanks behind the rear end... here's an article I did on mine and John (56panelford) has a 56 panel he brought back from the grave... he's a panel guru... drop him a pm and he'll help you out I know
http://jniolon.classicpickup.com/mus...ankarticle.htm
john
john
Mine is a 1950 F2 but the principle is the same. I understand that certain mustang tanks work on 1955s. If you do a forum search on gas tanks they should come up.
Received 4,112 Likes
on
on
Here it is. This is in a Chev C10 chassis that I used for my panel but frame widths are the same but this frame is beefier that the Ford frame so had to do a bit of trimming to place between the rails but would fit the Ford frame without any problem. I did have the spout re-located back a bit further and a larger tube installed. Another option would be the 78 full sized Bronco tank I used for my pickup
John,
Don't know how I missed this but your through the frame mount is where I came up with mine.
James,
If I had this to do over I WOULD NOT install a GM/Chevy tank like I did. I've not been able to find a salvage yard with a Maverick (not a Mustang) tank but in reading post I believe the fill tube can be routed out the BACK presumably between the floor and the bumper.
You do not want a hole in your floor of any kind so there is no way fumes can make it into the cargo/cab area.
https://www.ford-trucks.com/forums/1...d-you-use.html
James,
I used a Mustang tank in my panel. Used the stock Mustang fill (center rear of tank) but routed the fill out to the side of the panel. Fills a little slow. If I was to do over i would still use a Mustang tank but add a fill on the side and go through the frame to a fill in the side of the panel.
bobj49f2
07-21-2017 03:26 PM
teched
01-26-2011 04:07 PM
Studebaker
12-16-2008 02:48 AM
Mich 41
08-10-2007 02:06 AM
