Help with oil for 9 inch rear end
I am wondering what type and weight of oil to put in the rear diff. I have a 1967 f100 with a 352 and 4 on the floor. There is no power or performance upgrades on my truck. I seem to find allot of info for gear oil type for trucks that are used for racing and/or the track, but nothing for an occasionally driven truck. I don't hot rod or abuse my truck when I'm driving. The oil that is in there now is ultra thick, almost more like a grease than an oil. What does ford reccomend?
You'll need 5 pints of gear oil to fill the rear end. This will require buying 3 bottles of gear oil.
IF you have a limited slip differential, you'll need 4oz of friction modifier. Pour the friction modifier in first followed by the gear oil until the oil just starts to run out the fill port on the 3rd member.
If you have an open (single track) differential, the friction modifier will not be required.
RobS10
10-24-2007 10:25 AM
GSX1300R
12-26-2004 10:48 PM
