Accelerator pedal not working
Old Aug 21, 2017 | 08:50 PM
bird-n-buck's Avatar
bird-n-buck
Trailering
I have a 97 f350 powerstroke. I went out and started it up put in drive pushed on the pedal and nothing. I got on here and read to check throttle positioning sensor and the idle validation switch. Put a new tps on and the idle switch was working when the pedal was moved. Looked some more under the hood and found a rat had nested so I spent hours looking for chewed wires. Finally found one chewed into on the bundle of wires to the left of the pcm. So I soldered that one back together. I start it up and still no pedal and the transmission light on the shifter is blinking off now. We put a reader on it but it will not communicate with the reader. Where do I go now.
Thanks
Old Aug 22, 2017 | 05:48 AM
SchaefferUSMC's Avatar
SchaefferUSMC
Any check engine light when you step on the throttle? My truck does that sometimes and I have to wiggle the connector on the idle validation switch. I always get a cel when it happens though.
Old Aug 22, 2017 | 12:10 PM
bird-n-buck
Trailering
The cel has been on the entire time. I thought I would be able to at least read some codes.
Old Aug 22, 2017 | 12:52 PM
madpogue's Avatar
madpogue
You need a device that communicates specifically with our generation of PSD. Do you have a Windows laptop/notebook/tablet? If not, do you have an Android device?
Old Aug 22, 2017 | 01:55 PM
bird-n-buck
Trailering
I think we do, my wife just got a samsung j7 skypro phone I think they are android and I think my grandaughter has a laptop. I guess these can be used to scan for codes somehow.
Old Aug 23, 2017 | 08:40 AM
echo95's Avatar
echo95
You need to download the Torquepro app to the Samsung phone and pick up an ODBII blue tooth dongle like the one linked below. Total cost is less than $30. This app will read your codes and also monitor sensors that you select. It is very handy, and I use it on all my vehicles to read codes or monitor sensors to help troubleshoot.
https://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
There is a good thread on the 99 & up side on the Torque Pro App linked below.
https://www.ford-trucks.com/forums/1...e-pro-faq.html
Wish you luck. My dead pedal was a sticky IVS, so I'm not much help to you since yours sounds like wiring.
Old Aug 23, 2017 | 09:27 AM
bird-n-buck
Trailering
Thanks I will give that a try.
Furr308
Jan 3, 2016 04:43 PM
SLAMMIN 22
15
Feb 13, 2011 07:02 PM
newportman
Jan 19, 2011 10:45 PM
welder2000
Mar 26, 2004 07:08 PM
Superdave
16
Jun 10, 2003 12:40 AM
