2012 psd no dash power,no crank.
Old 08-20-2017, 06:12 PM
Cobrajet1967
Cobrajet1967 is offline
Cobrajet1967 is starting off with a positive reputation.
Stopped at the store,came out, started truck,ran for two seconds,shut off, hasn't run since,had no codes,or any other issues.
I have checked all the fuses,breakers,main power supply off of passenger battery,still nothing,
I have head and taillights,power points on dash,dome lights,chime for headlights.
79674 miles.HELP!
Old 08-20-2017, 06:58 PM
onequicksportster
onequicksportster is offline
onequicksportster is starting off with a positive reputation.
79674 miles.HELP!
Did you by chance use the parking brake? Could be the wire bundle down by the parking brake came loose.....
Old 08-20-2017, 08:09 PM
Cobrajet1967
No,I didn't use the parking brake,is there that much tied to that bundle? I have seen the issues on older trucks in some posts. I will give it a look,kinda need this truck for labor day weekend,any help is appreciated.
Old 08-20-2017, 08:19 PM
Cobrajet1967
Checked the wiring associated with the parking brake, didn't see anything unusual or hanging loose on that or the bundle above it.
Old 08-20-2017, 08:24 PM
onequicksportster
I'm pretty sure there is a connection that comes loose in that area.. At least if memory serves me correct, it seems I have read about it here somewhere..
Old 08-21-2017, 11:21 AM
Cobrajet1967
Could the inertia switch cause these problems?
I'm thinking it just shut off the fuel.
Old 08-26-2017, 09:33 PM
Cobrajet1967
Update
A large stereo equipment installer in town installed a drop-down dvd player in my truck,the wire came down the driver's side pillar,under the dash at the emergency brake release handle and into a fuse holder,and then tied into the ignition in the steering column.
The wire was rubbed through at the e brake handle,shorting the ignition fuse for the truck, instead of the player fuse which was over amped at 30 amps,needless to say,it wasn't the trucks fault,but had to have numerous, computers and modules re flashed.
So watch your aftermarket wiring,whether you did it or a professional.
They are paying for the damages.Thsnks to all for the help
Normy
Aerostar
08-10-2018 06:43 PM
muddy84f250
24
07-12-2013 01:08 PM
TT66
06-15-2013 09:31 PM
40dog
09-19-2008 08:00 AM
kimanded
06-29-2008 07:49 AM
Quick Reply: 2012 psd no dash power,no crank.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
