[1992 5.0] Ignition coil keeps burning out
I've burnt through 3 ignition coils in a combined probably 15 minutes of run time. My truck has been out of commission for a couple of months until I found the time to change every seal and gasket but the heads. After replacing everything the truck seemed to run fine. I drove it around the block a few times and noticed the valve cover was still leaking. I resat the valve cover and all was well, minus the liter of oil I dumped on the driverside exhaust manifold.
The next day I started her up and let it idle for 5 minutes or so and it died out of nowhere and wouldn't start back up. I traced it back and found out the ignition coil wasn't getting a spark but the wires running to it were functioning as they are supposed to. They ignition coil was old so I didn't think much of it, and went to the parts store to buy a new coil.
I slapped the new coil in and she fired right up and ran for a couple of minutes before dying again out of nowhere. I decided to swap out all the plug wires, and the 4 spark plugs I accidentally dumped oil all over (the old plugs only had around 5,000 miles on them, felt no need to change both banks) Still no dice, so I went back to the store and got another coil.
I put it in and started the truck, it ran for a minute or two with a more noticeable misfire than before and then died and wouldn't start back up.
Do I just have bad luck and got stuck with two different defective coils or is something going on that is burning out my coils? I tested the voltage of the wires that connect to the ignition coil, the positive cable puts out 12v and the other wire makes my light tester flash while cranking.
cgi2099
12-12-2011 09:37 AM
78bigunns
17
04-08-2008 06:43 PM
