02 f250 7.3- Injector Solenoid?
#91
After engine temp reached 180* the PERDELs were all over the place.
#1 0.00
#2 0.00
#3 1.75
#4 0.00
#5 3.94-4.31 If I hold the brake and put it in drive it will go to 6.61! If I push on the brake only it will go to 5.50.
#6 0.00
#7 .88-1.50
#8 1.55-2.00
EOT-180*
ICP-470-510
Torque converter?
#1 0.00
#2 0.00
#3 1.75
#4 0.00
#6 0.00
#7 .88-1.50
#8 1.55-2.00
EOT-180*
ICP-470-510
Torque converter?
#93
#94
"CCT test: #5-fail
With valve covers off the #5 injector will not squirt oil even after warm."
"#5 3.94-4.31"
Your tread are somewhat long for a foreigner to read - but I have done my best.
Are your #5 squirting oil when cold now or not?.
If not.
What if your poppet valve are stuck or partly stuck in the bore hence the no oil from the spouts?.
Helge
"#5 3.94-4.31"
If not.
Helge
#95
"CCT test: #5-fail
"#5 3.94-4.31"
If not.
Helge
"#5 3.94-4.31"
If not.
Helge
When I perform the CCT I am getting codes P0275 and P0281. Contribution failure on #5 and #7.
48 hours ago I had only P0275, #5 failure contribution.
So very confused.
#97
#98
#99
Thank you for the help from everyone on this monumental problem.
#100
I have a 02 7.3 with a no start situation. I have replaced all the usual ICP, CPS, LPOP, Glow Plug relay, BPS, tested HPOP- good, fuel pressure - good, Removed IDM and tested Ohms - passenger side bank has 3 injectors with a reading of around 10 ohms. I get that those should be replaced but would that cause a no start?
No7Brand
05-15-2018 03:15 PM
mototrig
09-08-2015 06:48 AM
Sharonl12
37
07-01-2013 03:13 PM
Spectramac
07-26-2011 06:59 PM
